20 Most Recent
Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner Questions & Answers
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
11 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
Yesterday
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
on Apr 20, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
