20 Most Recent Krups ProAroma 453-42 Coffee Maker Questions & Answers
I need a manual for a Krups Pro Aroma 453-42
Hello, franI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
10/29/2011 12:38:16 AM • Krups ProAroma... • Answered on Oct 29, 2011
The coffeemaker tube leaks on my Krups ProAroma 452
I have the same problem. The rubber elbow seems to have shrunk with aging. Krups customer service pointed my to SmallAppliance.com for a replacement part. It appears that "Krups 0067516 Coffeemaker Tube" is the proper replacement. It is a special order part that may take 6 weeks to ship. The elbow pulled off a connection inside the coffee maker and I hope that the replacement will just slip back on. While I haven't completed the repair, I think I'm on the right path.
9/18/2010 7:27:05 PM • Krups ProAroma... • Answered on Sep 18, 2010
Krups 453 - coffee is weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
4/1/2009 2:57:02 PM • Krups ProAroma... • Answered on Apr 01, 2009
Krups 453 coffee maker - won't to brew/heat
I just had the same failure, but fortunately, had already bought a used 10-cup unit a few months back as a spare.
The component in question is a thermal circuit breaker, of the sort which does not reset. Once activated, it is destroyed,
I have been unsuccessful locating the same component on the internet, but it seems to be a very high temperature unit, with the nomenclature "Tf 318 C" which because of the lower case "f", leads me to conclude that it's designed to trip at 318 degrees, C, or a very healthy 604 degrees, F.
Similar fuses in other appliances range around 230 degrees C (446 degrees F),  which is in the ballpark.
The failure is easy to verify.  If blown, there will be powdery white residue on the inside of the bottom plastic cover near the part.  Also, an ohmeter will show an open circuit across the contacts.  (Unplug the unit before measuring!)
Screws to remove the bottom cover are three tamper resistant torx screws.
If I am unable to find an exact replacement, I will use a thermal fuse in the same power and temperature range (10 Amps, 300 degrees C trip).
Because my unit unequivocably did not experience over temperature conditions, I suspect this is a component aging issue and that there is no other problem with the coffee maker.
Supporting this is the fact that the unit works fine after I moved the good part from my spare coffeemaker to the dead one.
12/27/2008 5:22:00 PM • Krups ProAroma... • Answered on Dec 27, 2008
2answers
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
12/14/2007 4:41:53 PM • Krups ProAroma... • Answered on Dec 14, 2007
Krups EA 80 milk frother not working properly.
Question edited for typos and spelling. It is a 'frother' rather than a 'throther'.The roaring is normal, you are releasing steam from a boiler. Steam wand issues are usually caused by cooked milk solids inside the wand. You need a good enzyme cleaner like Rinza. Help and videos in the linkhttps://www.google.com/search?q=Krups+EA+80+milk+frother+not+working+properly..
2/21/2024 6:46:14 PM • Krups Coffee... • Answered on Feb 21, 2024
Need Natur Actin Filter for this model.
Did you mean 'Natural Action' filter? That is nothing to do with the Krups Pour and Serve. https://www.google.com/search?q=Natur+Actin+Filter https://www.google.com/search?q=Krups+Type+452 ..
1/30/2024 9:17:41 PM • Krups Coffee... • Answered on Jan 30, 2024
2answers
Krups EA89150 control board troubleshooting
I think this is the manual, Smart Advisor. And he will probably have to contact the manufacturer anyway. I don't find the info he is looking for. User manual and frequently asked questions KRUPS EA8150 Compact PISA Super Automatic Espresso Machine EA815050 EA815050 (krupsusa.com)
1/20/2024 10:01:12 AM • Krups Coffee... • Answered on Jan 20, 2024
Krups Pro KM7000. How do you fix a dim display on it please?
Dim displays are normally caused by failing, bulging or split capacitors on the back of the display. They regulate voltage to the display. If you are proficient with a soldering iron, you can do it yourself. https://www.google.com/search?q=Krups+Pro+KM7000+dim+display ..
12/28/2023 2:51:08 AM • Krups Coffee... • Answered on Dec 28, 2023
Hi we have krups xp9000 where the coffe does not come out anymore,water comes out but not coffe. Coffe comes out in tray and some comes out on table, some adwise how to repair or some ideas, Tore
There are three things it could be, the motor that drives the brewing unit, the brewing unit itself or the pressure relief valve. You need to operate while looking inside with a torch to see what is happening. This is done with the back, the top and the beans side side cover removed for visibility.
8/30/2023 9:53:17 PM • Krups Coffee... • Answered on Aug 30, 2023
I own a Krups EA9000 bean to cup coffee machine, it has a water leak through different operations?
When you buy these machines, they don't tell you that they need dealer servicing every 6 to 12 months. You need a brew head service kit which involves replacing all the seals and O-rings. The heat and pressure makes the seals deteriorate and leak. Also, it is not using cleaning solution, you have pipe blockages. They are only about 1/8" internal diameter.
7/1/2023 2:25:08 AM • Krups Coffee... • Answered on Jul 01, 2023
I need service manual for KRUPS FBD 145003P. Can anybody help me?
Unfortunately not in the public domain yet. You would have to ask the company direct. https://www.google.com/search?q=KRUPS+FBD+145003P+%22service+manual%22 ..
5/4/2023 6:23:19 PM • Krups Coffee... • Answered on May 04, 2023
Krups ProAroma 453-42 Coffee Maker Logo
14 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
