20 Most Recent
Luminox Navy SEAL Dive 3103 Wrist Watch Questions & Answers
Watch stops when stem is fully engaged
It sounds like the setting mechanism has gotten out of place or is bent. A qualified watchmaker can fix this for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Trouble with the hour hand
this is an hour wheel problem and can only be corrected by replacing the gears that are damaged then resetting the hands...only a professional trained watchmaker should handle this, there really is no other simple way to correct it
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
