20 Most Recent Danby Silhouette Dual Zone DWBC14BLS 13.90 cu ft Built-in / Free Standing Wine Cellar / Beverage Center Cooler, Holds 165 Soda / Beer Cans, Five 2L bottles, and 77 bottles of Wine, or Max 154 bottles of Wine, Two separate, independently controlled temperat Questions & Answers
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes. Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
9/26/2016 11:41:40 PM • Danby Silhouette... • Answered on Sep 26, 2016
Whirlpool Range Model WBP 34500. I need a wiring diagram for it please?
Unfortunately not for that model. I realize this is an old question but it is stuck and needs answering to get rid of it. :>D https://www.google.com/search?q=Whirlpool+Range+WBP+34500+wiring+diagram ..
4/9/2024 5:46:28 AM • Kitchen Ranges • Answered on Apr 09, 2024
Sirius SU1 Wall Mount Chimney Range Hood, 600 CFM. Not working at all. Replaced board?
It sounds like your new board is faulty or there are bad connections to and from it. Have you asked Sirius Helpdesk Support? https://www.google.com/search?q=Sirius+SU1+no+power ..
3/25/2024 11:28:36 PM • Kitchen Ranges • Answered on Mar 25, 2024
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help. 35 years + restaurant equipment repairs. Theseafox Enterprises
3/23/2024 12:56:00 AM • Kitchen Ranges • Answered on Mar 23, 2024
How old is Whirlpool Gas Range Model #10116557A
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
3/14/2024 2:02:48 AM • Kitchen Ranges • Answered on Mar 14, 2024
Why is my commercial oven emitting so much Carbon Monoxide?
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with. Are you on mains gas or propane because the jets are different. https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide ..
3/1/2024 12:19:25 AM • Kitchen Ranges • Answered on Mar 01, 2024
Oven temperature not what it should be. Set at 350 and my oven thermometer only went up to 335.
That seems quite common. Place your temperature sensor, alongside the therocouple of the oven, to check its accuracy.
2/23/2024 9:36:59 PM • Kitchen Ranges • Answered on Feb 23, 2024
Where can I find a maintenance manual for a Teba TFB21Y gas cooking stove
There isn't one for the reason I stated before. Call for service. https://www.google.com/search?q=Teba+TFB21Y+service+manual The only thing available is Parts, but that is for service engineers.
Teba TFB21Y (TFB21F20) oven spare parts - FixPart
fixpart.ie https://fixpart.ie > oven-spare-parts > tfb21y-tfb21f20 Teba TFB21Y (TFB21F20) oven spare parts needed? ? 16+ spare parts deliverable. ? Next day delivery* ? Customers give us a 9.0. ..
2/23/2024 4:04:39 AM • Kitchen Ranges • Answered on Feb 23, 2024
2answers
Oven won't turn on but gas and range hood are working.
Here is text followed by a YouTube. Possible reasons why your oven won't turn on even though the gas and range hood are working: Igniter: The igniter is responsible for lighting the gas in the oven. If it's faulty, the oven won't turn on. You can check if the igniter is working by looking for a glow when you turn on the oven. If there's no glow, it's likely that the igniter needs to be replaced. Wires: The wires that connect the oven to the power source may have come loose or be damaged. Check the wires for any signs of damage or looseness and replace them if necessary. Safety valve: The safety valve regulates the flow of gas to the oven. If it's faulty, the oven won't turn on. You'll need to hire a professional to repair or replace the safety valve. Top 4 Reasons Oven Won't Turn On - Gas Range Troubleshooting (youtube.com)
2/22/2024 12:56:43 PM • Kitchen Ranges • Answered on Feb 22, 2024
Broan Nutone Range Hood RL6100C, high speed fan works but low speed does not. I am wondering if a new switch is needed?
Yes it is likely to be the switch. I have one of these as well. Remove the switch and test it with a multimeter. https://www.google.com/search?q=Broan+Nutone+Range+Hood+RL6100C ..
2/16/2024 6:29:14 AM • Kitchen Ranges • Answered on Feb 16, 2024
Where can I get a thermocouple for a Teba TFB21Y gas stove
It appears they are made in Turkey and for some reason my Malware program doesn't like their webpage
Home ' Teba Heating Stoves & Pellet Stove - We've been ...
teba.com.tr https://www.teba.com.tr Teba Heating Stoves Produce Ideal Solutions For Different Places With Environmentally Friendly, High Efficiency, Comfort, Savings, Safe And Convenient Use ... Parts https://www.google.com/search?q=teba+TFB21Y+parts Thermocouples are pretty standard. https://www.google.com/search?q=teba+TFB21Y+thermocouple ..
2/16/2024 4:10:10 AM • Kitchen Ranges • Answered on Feb 16, 2024
How to replace Forno gas range oven igniter please?
Not a make we know here. It is just a matter of finding the unit, undoing the screws and wires https://www.google.com/search?q=replace+forno+gas+range+oven+igniter ..
1/28/2024 11:49:16 PM • Kitchen Ranges • Answered on Jan 28, 2024
Danby Silhouette Dual Zone DWBC14BLS 13.90 cu ft Built-in / Free Standing Wine Cellar / Beverage Center Cooler, Holds 165 Soda / Beer Cans, Five 2L bottles, and 77 bottles of Wine, or Max 154 bottles of Wine, Two separate, independently controlled temperat Logo
1 questions posted
Top Danby Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danby Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Danby Kitchen Ranges
Most Popular Question
danby dwc2121bls dual commpartment wine
  • Kitchen Ranges
