20 Most Recent
Krups GVX2-14 Burr Coffee Grinder Questions & Answers
Missing user manual
just shearch your cas manual though google and it should come up straight away and you can download the manual for free i done it for my cars manual hope this helps
'Automatic maintenance on the screen = ground coffee ejected
All of these automated coffee machines need regular maintenance. When was it professionally services by the dealer? My 6 machines in an airport environment needed service every 4 months. At home, probably every 12 months. Seals need replacing and moving parts cleaned and lubricated. In my opinion these machines are totally unsuited for home use. So many issues show up on this website and all makes, but Saeco are the worst..
Dolce gusto krups infinissima red light
The blinking yellow-green and solid red light on a coffee machine typically indicate an error or problem with the machine. Without more specific information about the make and model of your coffee machine, it is difficult to say for sure what the problem is. However, here are some common issues that can cause a coffee machine to display these lights:
Blinking yellow-green light: This light may indicate that the machine is in a warm-up or preheat mode.
Solid red light: A solid red light can indicate several different problems, depending on the machine's model and brand. Some common causes of a solid red light include a low water level, a clogged or dirty brew head, or an issue with the machine's heating system.
It is recommended to check the user manual for your coffee machine to determine what the specific light sequence means and how to address the issue. If you don't have the manual, you may be able to find a copy online by searching for the make and model of your machine. If you are unable to resolve the problem, you may need to have the machine serviced by a professional.
Krups XP4050 brews but stops midway (after 4-5 secs) & then the beeping sound + blinking button lights comes on. Anyway to resolve this? Thanks mate!
There are a few potential causes for the issue you are experiencing with your Krups XP4050 coffee maker. Here are a few things you can try to troubleshoot the problem:
- Check for any blockages or obstructions in the water line or pump. Make sure that the water line is clear and that the pump is functioning properly.
- Check the water level in the tank. Make sure that the water level is above the minimum level required for brewing.
- Check the filter for any clogs or blockages. Make sure that the filter is clean and free of any debris.
- Check the coffee grounds for any issues. Make sure that the grounds are fresh and not stale or clumped together.
- If the issue persists, you may want to try running a diagnostic test on the coffee maker. Consult the manufacturer's manual for instructions on how to do this.
If none of these steps resolve the issue, it is possible that there is a problem with the coffee maker's internal components. It is recommended to contact a professional for further assistance in diagnosing and repairing the issue
