20 Most Recent
Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr Questions & Answers
How to wire the superwinchS4000 to my quad
Here is a sample of how to wire a winch. I have built my own box with relays to swap the power for reverse etc I'm not sure if you have to buy an extra kit where someone has done the work for you or not. It looks neater when purchased.
Click here
11/26/2013 8:15:47 PM •
Electric...
Answered
on Nov 26, 2013
I havea LP8500 superwinch. I
This may help (or maybe not):
The Black wire is the ground wire, and the other two are considered Hot wires, and their
order does not matter - they carry 240 Volts AC.
So, once you identify which terminal on the solenoid is ground, connect Black to it, then just hook up the remaining two Hot wires in any order.
7/4/2011 6:38:15 AM •
Electric...
Answered
on Jul 04, 2011
I have a 14 volt
Not only do you need a 12 volt supply (13.8V) to operate this winch, but you also need a.) wire large enough to carry the electrical load, and b.) a power source that has the necessary current (amps) to turn the motor.
If you have wires that are too small, they will heat up and not be able to deliver the current (amps) required by the motor. If your power source is to small - it can not supply the current required. The result of either conditions is "voltage drop". This can be explained the same way your car needs a 12 volt car battery to start. If that car battery was dead, you couldn't connect eight "D" cell batteries (8 x 1.5volts = 12 volts) together and attach to the car's battery cables and expect it to start. This is because the amount of current available in the car battery is hundreds of time greater than eight "D" cell batteries - even though when the D cells are connected in series - both systems deliver 12 volts.
If neither of the above conditions is present, then there could be an electrical problem with the drive motor itself. This could be a shorted / melted winding or other electrical connection that is not right, even if the drum spins freely.
4/4/2011 4:56:17 PM •
Electric...
Answered
on Apr 04, 2011
When I try and use the winch all I get is a
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
1/24/2011 12:52:09 AM •
Electric...
Answered
on Jan 24, 2011
Wiring up super winch
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
9/21/2010 3:33:03 PM •
Electric...
Answered
on Sep 21, 2010
Whats wrong with my electric hot water heater 240v single element
It requires a 2 pole ganged breaker to meet code and guarantee the breaker is on two legs of the single split phase service. That in itself doesn't explain the 120 volts at the heater element.
Replace the two single breakers with the appropriate 2 pole ganged breaker. Before connecting the feed to the heater, turn on the ganged breaker and measure voltage across the breaker. If not 240VAC then there is a problem at the breaker panel.
If there's 240 at the breaker then you've somehow wired the thermostat incorrectly but can't imagine what you did.
12/8/2022 2:04:39 PM •
Electric...
Answered
on Dec 08, 2022
Where is the circuit breaker on a electric cooker
cookers usually use a thermal fuse close to the heating element fuses range from 150c to 190c.once you find the fuse check it with an ohmeter it should have continuty. the thermal value should be printed on the fuse.
9/7/2021 5:32:59 AM •
Electric...
Answered
on Sep 07, 2021
Why does my 27gal powermate smell like electric fire as soon as I turn it over?
Likely a motor capacitor is failing causing excess current (heat) in the motor windings. Does the motor get hot?
OR, a poor connection in the motor start or run circuit either at the centrifugal switch or the capacitors. A loose connection may overheat and emit a burnt resin odor.
Regardless, you'll want to fix it ASAP as it will likely only get worse resulting in higher repair cost.
8/8/2021 9:00:58 PM •
Electric...
Answered
on Aug 08, 2021
