20 Most Recent Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Questions & Answers
My Water Ace R520C-T7 jet pump wtih pressure tank
Inspect the check valve to see if the flapper is stuck shut causing a restriction in the .
6/10/2016 6:20:01 AM • Water ACE... • Answered on Jun 10, 2016
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
2/5/2015 11:53:43 PM • Water ACE... • Answered on Feb 05, 2015
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
1/6/2015 9:28:45 PM • Water ACE... • Answered on Jan 06, 2015
What is the motor winding
Pump hums, it is burned out, or the capacitor is bad http://waterheatertimer.org/Color-codewire.html#motor Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/22/2014 6:27:34 AM • Water ACE... • Answered on Dec 22, 2014
So what could be causing this to happenat camp we have well water and the pump keeps tripping and shutting off
blocked pick-up screen could cause the pump to overheat, old pump could be simply overheating, mineral build up in pipes could be causing over pressure at the pump creating overheating....
12/20/2014 1:10:22 AM • Water ACE... • Answered on Dec 20, 2014
My pump will not shut off
check the float assembly for freedom of movement. A jammed float will give a false indicator to the pump.
12/20/2014 1:04:03 AM • Water ACE... • Answered on Dec 20, 2014
Water ace portable 1/6 hp submersible pump hums
sounds like a jammed impeller or blocked intake screen.
12/20/2014 1:00:45 AM • Water ACE... • Answered on Dec 20, 2014
My R520-T7 pump hums but will not turn on
sounds like a jammed or detached impeller, located at the bottom of the pump motor. Repairs are unreliable and replacement is inexpensive ($130 for a comparable pump) recommend replacing the pump.
12/20/2014 12:39:14 AM • Water ACE... • Answered on Dec 20, 2014
Float switch
Bad switch If you need further help, reach me via phone at https://www.6ya.com/expert/scott_87482045335a4757
9/7/2014 4:01:35 AM • Water ACE... • Answered on Sep 07, 2014
2answers
How to replace a sump pump
There are 2 schools of thought regarding maintenance: you can carry out preventive maintenance (calendar based or hours run)... or, on condition maintenance... i.e repair it when it breaks down. What, is the consequence of a failure... if it's 'bad' replace it.... if not, wait until it fails. Hope this makes sense.
8/28/2014 11:01:52 PM • Water ACE... • Answered on Aug 28, 2014
0answers
0answers
0answers
0answers
0answers
High Electric Bill due to Well Pump Cycling On Frequently
The short run time of the pump indicates very litttle water volume is needed to reach to turn off pressure. To me this indicates you may have two problems. There is a leak somewhere in the system that allows the pressure to drop to the turn on point. Any check valve will fail eventually so barring any other leak that is your problem. I would think only one check valve is needed in the system so the second one may have been added to crutch the first one leaking. Normally the one check valve is placed on the pump before it is attached to the well pipe. The pump must be removed from the well to accomplish the replacement. The second problem has something to do with the storage tank. If the pumps runs whenever you open a faucet or in your short cycle situation, then your tank is way too small or it is "water logged". Assuming it has been sized correctly, which means at least 20 gallon capacity then air needs to be added to the tank which will compress when the pump adds water until the high pressure setting is reached. When water is release to the house the air will expand until the low pressure setting is reached and the cycle repeats. The point here is that a significant quanity of water flows between pump cycles. If your tank was installed in perhaps the last 20 years then it is likely a bladder type whitch contains the water so it never comes in contact with the steel tank, preventing internal corrosion and leaching of metals into the water. If the bladder has failed then the formally isolated air will have been absorbed by the water and your short cycling condition develops. That is what happens in non bladder tanks so air needs to be added periodically. I think all bladder tanks have a car tire like valve stem attached to the tank so that the opperating pressure can be set by the manufacture. The valve stem rairly leaks so bladder failure causes the loss of the air in the tank. There should be a label on the tank specifying the factory pressure. Use a tire gauge to test for the proper pressure. Add air if it is below setting.
12/12/2013 6:28:05 PM • Water ACE... • Answered on Dec 12, 2013
220 Volt Wiring Diagram
black hot red hot white neutral green ground get help to be safe
11/6/2013 2:30:34 AM • Water ACE... • Answered on Nov 06, 2013
0answers
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
71 questions posted
Top Water Electrical Supplies Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Water Electrical Supplies
Most Popular Question
replace sump pump
  • Electrical Supplies
