20 Most Recent
Jura Impressa F50 Classic Automatic Coffee Center Questions & Answers
Jura f50 repairing
Probably just needs to be cleaned inside.
This is good video for most models. Parts Guru can do it for you if you don't think you're up to it. Or rebuild the brew group for you.
https://www.youtube.com/watch?v=mZwkqPeZ0QY
How to fix jura not coffee sign?
It is wanting grounds dropped into the trap door on top. If you open that trap door there is a sensor on the hindge that causes it to expect ground coffee to be dropped in there. This is how you would make a decaf cup with caffeine beans in it or flavored with regular bean in the grinder.
Check to make sure the door is closed. It should return to "ready" in about 10 seconds. If not cycle the power by pushing the on/off button or pull the plug.
Instructions can be found here:
https://www.capresso.com/customer-care-instruction-booklets.shtml
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
