20 Most Recent
Sperry Instruments DM6450 64 Series Digital Multimeters Questions & Answers
Why does my sperry DM6450 multimeter read "connect
Are you connecting your leads to the proper terminals on the meter? There are, what, four of them? Easy to mix up.
If it still isn't working, then you might have a bad connector on your multimeter.
1/16/2019 8:43:38 PM •
Sperry...
Answered
on Jan 16, 2019
What does "open neutral" mean?
The "neutral" wire in home wiring is always the "white" wire. The hot line is always the "black" wire or in the case of a multiple conductor, can be just about any color but white or green.
Green is circuit ground, the nasty 3rd pin on the plugs we use, but a very important safety feature.
When you have an "open neutral" reading it means that the "white" wire has come loose some place in your wiring. A broken or loose wire is referred to as an "open" in electrical terms.
I assume you are plugging an outlet tester in and get this indication. It may just be in the outlet you are testing or someplace else between the outlet and the circuit breaker.
10/4/2010 8:57:52 AM •
Sperry...
Answered
on Oct 04, 2010
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
