20 Most Recent
Philips Philishave HQ8894 Electric Shaver Questions & Answers
Why won't Philishave won't stay switched on?
If it will not continue running when turned on, your battery may be about dead and need replaced. Replacement battery and repair service can be obtained from shaveroutlet.com
8/12/2014 3:47:06 PM •
Philips...
Answered
on Aug 12, 2014
Battery for philishave hq8894
you will find the compatible battery at shaveroutlet.com. See link belowhttp://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/norelco-philips-liion-battery-cell-for-select-models-p-380-1599.html
4/8/2013 2:10:02 AM •
Philips...
Answered
on Apr 08, 2013
Battery not holding full charge
You will find the correct battery for model 8894 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-liion-battery-cell-for-select-models-p-380.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the battery from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old battery with small needle nose pliers rather than unsoldering it from the circuit board.
This allows the old battery to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new battery to the old existing tabs
2/27/2011 3:34:04 AM •
Philips...
Answered
on Feb 27, 2011
When i try to turn
It signals that it needs to be recharged. If it does the exact same thing after a recharge it means that the battery inside it have aged and no longer hold the charge - it should be replaced.
Unfortunately the battery is a custom one that is available only thru Philips repair centers and it's expensive. Actually it's so expensive that it's not worth replacing - for almost the same price you can buy a new shaver.
2/7/2011 7:15:30 AM •
Philips...
Answered
on Feb 07, 2011
