20 Most Recent
Philips HD-5702 Questions & Answers
We've tried to start our Phillips Espresso Bar
There are merely 3 controls on the unit, two swithes on the right hand side and a turn knob on the left hand side. Press the upper switch - power should go on as indicated by a red light, the orange light of the lower switch indicating the unit is heating up. When the orange goes off, you can press the lower switch whitch starts the compressor to pump up the boiling water into the coffee. During coffee preparation the orange light may go on from time to time indicating the unit is reheating. Stop the pump when coffee is enough. When turning the knob on the left by 90degrees the unit will produce steam and feed it out through the metal nozzle at the left of the unit.
Seaco Syntia hd8837. Why is it stuck in an endless descaling loop?
Descaling Problem SOLVED!
Folks, I really hope this helps a lot of you. I too encountered the dreaded descaling problem where it gets stuck in a loop and never finishes. I thought the machine was toast and see so many reviews that people experienced this and had to return the machine.
I tore apart the machine and figured out the issue and the super simple fix!
What happens is the water level sensor does not know it is running out so when the tank empties due to running dry, it never completes the cycle.
Where the water basin goes, if you look at the back lower down, you will see a small rectangular protrusion. This is the water level sensor that works by measuring capacitance. You know how sometimes your machine runs completely out of water and you have to prime it with the tea/hot water button? This is why! When you put the tank in full, water splashes over the edge and down the back. It coats the outside rear of the tank and the sensor with water so the machine thinks it still has an adequate level of water but then all of a sudden runs dry.
The FIX:
Take a paper towel and dry off the water level sensor and the back of the tank. When you put the tank in, do not fill it too high and put it in gently to avoid water spilling out.
Simple as that...fixed!
https://www.fixya.com/support/t7525311-machine_seems_stuck_in_descaling_mode
and videos and help from Philips
Press and hold (for about 6 seconds) the hot water button until the descaling light turns off.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00Uzvq3eDBHCFOUx_2MVtsuTL0uPQ%3A1606349189530&ei=hfG-X6TtH5Wq1QGCjanwDg&q=Seaco+Syntia+hd8837+stuck+in+endless+descaling+loop
I have descaled my Philips Syntia espresso machine regularly, but no water is coming out. I think there must be limescale buildup internally. How can I get the covers off to see the hoses?
First, I'm not a Philips technician. Also don't recommend De-scaling of table top machines UNLESS the MFR provides the de-scaler and recommends it. Several things can prevent the water flow in these small machines. It's probably the vibration pump but suggest following the following list to check if everything is in order.
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
I bought my senseo philips HD7825. I loaded the water then plugged it in then I added the coffee pod. However, the power light kept blinking (slowly) as though it is heating up. But it is not heating.
Hi
Quite possible the boiler has failed. You would need to disassemble to check (with a multimeter) if the boiler heater elements are a continuous track from one terminal to the other. Boilers often fail - else you have a electronics problem somewhere that will require a tech person check out.
The other thing boilers can do is to develop an earth leak between the heater element itself and the outside of the element - this will cause the machine to shut down your house's power supply if you have an Earth Leakage Safety Switch installed in your meter box.
Given this was an inexpensive machine and uses rather "odd bod" pods it may be time to consider something more 'common' like a Nespresso, Aldi or the Cafitaly style of capsules.
I especially like the Cafitaly capsules as they have more coffee than Nespresso, have 2 internal filters, can be refilled with ground coffee (I reseal top with wide cellotape) and can be refilled at least 4-6 times before they should be thrown away. Instead of around 30-50c a cup, refilled capsules costs me about 9c a cup - I get about 100 capsules out of 1Kg (2.2 pounds) of coffee.... beat that.
Cheers
Mike
