20 Most Recent Hitachi NR65AK Round Head 1-1/2-Inch to 2-1/2-Inch Positive Placement Nailer Questions & Answers
2answers
How do you remove piston cylinder to change o ring
Easy to remove the cylinder and piston/driver. Remove four head bolts and lightly tap head to release gasket. Push out driver by inserting rod thru nose then remove spring retainer holding the cylinder in place.. With retainer removed the cylinder should pop out. Sometimes the retainer will cause a bur to form on the body of the mailer making it s bit more difficult to remove. Good luck
2/21/2019 2:59:08 PM • Hitachi NR65AK... • Answered on Feb 21, 2019
How to set the alarm ( Discharge Temperature ) on Hitachi Next Series (V73 - Oil free Screw) Compressor?
Unfortunately, you don't provide a Model number 'V73' is Version 7.3 of the Software running the control panel. They have model number like in the front page of this manual, and in this particular Manuals website you can use the search feature. https://www.manualslib.com/manual/1652200/Hitachi-Next-Series.html#manual ..
3/28/2024 6:06:15 PM • Hitachi Air... • Answered on Mar 28, 2024
A Hitachi EC89 portable air compressor. It would pump, show pressure in one gauge not the other. Broken the pressure reducer. Put a new one on, same issue. Just using it to fill tires.
the regulator is used to control pressure. Is the knob turned completely clockwise. page 9 of instructions. Don't have yours copy and paste link https://www.metabo-hpt.com/docs/default-source/default-document-library/ec89_om.pdf?sfvrsn=51a32c66_0
9/30/2023 6:45:56 PM • Hitachi Air... • Answered on Sep 30, 2023
Hitachi impact wrench WR 18DBDL2 not working properly
I would check the main switch/speed control for a fault, assuming the battery is not exhausted that is.
9/27/2023 8:11:09 AM • Hitachi Air... • Answered on Sep 27, 2023
Wiring diagram for a Hitachi ec 12 air compressor
notify a dealer or manufacturer
10/5/2022 10:35:46 PM • Hitachi Air... • Answered on Oct 05, 2022
2answers
How do I remove the cover on my Hitachi air compressor
First, you have to determine how it is attached usually they are screwed or bolted into place or simply held into place by clips or pressure. But there are many different models so please post the model of your machine so it can be identified or even a photo.
9/21/2022 5:19:13 PM • Hitachi Air... • Answered on Sep 21, 2022
I have an Hitachi nail gun andThe bolts on the nose to the body keep breaking is there a solution to this problem the air pressure is always kept it between 100 psi
This is a common problem with this model - the typical reason for this is overdriving the piston which is usually caused by air pressure being too high. It can also be from using it on thin or soft wood (using it to nail plywood to plywood etc)
3/3/2021 2:09:25 PM • Hitachi Air... • Answered on Mar 03, 2021
How to replace control knob o ring on pancake compressor EC-510 model
This is not replacing an o-ring, unfortunately, this involves replacing the manifold #887-499 which contains the regulator. There are no regulator parts available.
3/3/2021 2:06:01 PM • Hitachi Air... • Answered on Mar 03, 2021
2answers
We have an EC79 Hitachi air compressor. The pressure relief is supposed to stop automatically when full, but this one turns ON and lets the air out. Once it opens, we have to turn the Hitachi off.
If u are talking about the bleed off that blows when the compressor shuts off. It should blow down for a short period then stop. If it dont stop your tank check valve is bad.
4/7/2019 9:34:59 PM • Hitachi Air... • Answered on Apr 07, 2019
Which battery I must remove on e02 error in osp-37s5ar hitachi air compressor?
There is no battery on that air compressor.
4/7/2019 12:55:40 AM • Hitachi Air... • Answered on Apr 07, 2019
Ec 12 Hitachi air compresser not building up air pressure
So the first (most obvious but sometimes overlooked) thing - check to make sure the tank drains are closed. Listen for a leak at the pressure switch - it will continue to leak after the compressor shuts off. If this is the case then you need a check valve (Part # 53A on the breakdown) If it builds pressure but not enough to shut off and there are no leaks I would look at the valves located in the head (Part # 14 on the breakdown) - piston rings are not a normal failure part on this model but could also cause this.
2/2/2019 6:12:21 PM • Hitachi Air... • Answered on Feb 02, 2019
Air pressure on my air compressor
This problem is usually caused by reed valves or blown gasket between head and valve plate. Easy to check. After the compressor reaches 45 to 50 psi, with compressor still running, remove the air filter and feel for good suction at the intake port. If the air seems to be blowing out of the intake, then valves are bad. If you feel good suction at the intake, then air is leaking from the discharge tubing or other fittings. Good luck
1/21/2019 4:26:22 PM • Hitachi Air... • Answered on Jan 21, 2019
How many ounces of oil is required for the Hitachi EC 99S ?
8 ounces of Synthetic Oil SAE15W40
1/19/2019 1:13:12 PM • Hitachi Air... • Answered on Jan 19, 2019
Use of Hitachi EC510 air compressor
Pressure gage A shows the pressure in the tank. Pressure gage B shows what you have adjusted the output pressure to be. If it is reading 0psi and it is new it is probably because the manufacturer has set it at that level. You have an adjustment valve on the front of your compressor. Rotate it until you see the pressure start to rise then keep going to where you want it set at.
11/27/2017 7:37:28 PM • Hitachi Air... • Answered on Nov 27, 2017
How much oil does a hitachi 119sa hold
here is a link to maintenance for these good luck Hitachi EC119SA 15 Amp 2 5 HP Lon Twin Stack Air Compressor Instruction...
11/19/2017 2:17:47 AM • Hitachi Air... • Answered on Nov 19, 2017
My Hitachi NR90GC2 nail gun won't fire any nails, even though I've cleaned it
insure that there is no debris ie., free from filings from the nails used or or ceck the feeder ports where the nail enters before it lives the port ( check for damage orifice or abstractions to it
9/30/2017 10:12:31 PM • Hitachi Air... • Answered on Sep 30, 2017
How do I remove the fan on Hitachi EC89
To remove the fan you will need a decent bearing puller - it is press-fit onto the armature shaft and doesn't come off easily. 6a00d83451706569e20120a7d7f5b4970b-msb1t3ug232aoetlvkk5zhhr-4-0.jpg
2/19/2017 3:06:11 AM • Hitachi Air... • Answered on Feb 19, 2017
Hitachi NR65AK Round Head 1-1/2-Inch to 2-1/2-Inch Positive Placement Nailer Logo
1 questions posted
Top Hitachi Air Tools & Compressors Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Air Tools & Compressors
Most Popular Question
remove piston cylinder change o ring
  • Air Tools & Compressors
