20 Most Recent
Vintage Jukebox External Speakers Shelf System Questions & Answers
Trying to hook new amp to old jukebox??? 1963 Rockola
Hi Randy,
I take it that the output from the jukebox is mono (only a signal and screen cable) and the connection to the amplifier is a phono plug. You could make up a cable by using a phono inline socket and two phono plugs. I would think that you could purchase one from your local electronic store. If you make one up it should be made using a screened cable.
Regards
Alan Hood
ami-man
UK
I have a rockola mystic jukebox & one side of the
Either a bad connection somewhere, or one channel in your amplifier is out.
Before you try anything else, switch the amp from 'stereo' to 'mono.' If the speakers come on, your amp is good and you simply have a bad connection somewhere between the amplifier and cartridge (thing that holds the stylus"needle"). Or, possible, but not probable, a bad cartridge.
For a quick fix, switch the amplifier to "mono" and then run all the speakers to the working channel.
In the meantime, if you're handy, try switching the speaker leads and such and see if you can isolate the problem.
Kyle~
Jukebox Rock-ola 464 wont turn on
Hi sullysfarm,
Here are the details of an action on Ebay for a 464 manual in the USA.
Rock-Ola 464 Jukebox Service Manual
Item number: 220350796639
With regards to your jukebox not working after transportation I would check to see that you have not caught any power switches that are on the back of the jukebox (these may be in a recess) or check all the plug in connectors for a loose connection.
Regards
Alan Hood
ami-man
UK
We just bought a 1974 ami, plugged it in and it pl...
If your Rowe Ami is indeed a 1974 model it will be a TI-2 or CTI-1 (chest style jukebox) this era of jukebox uses a search unit to push out selected pins on the unit A side and B side for the mechanism to search for and play.
If the search unit is pushing out the correct pins but the mechanism is not scanning to select those selections, it could be that the mechanism is skipping over the pins or it could be that the search unit is not pushing out any pins at all with the search unit motor just spinning around.
If you are in the UK then I could help you.
If you are in the USA try posting a request for help on
www.phonoland.com or on
www.collectingbanter.com
Regards
Alan Hood
ami-man
UK
[email protected]
Can auxiliary speakers be added to a Rowe/AMI
Yes they can. Above the amplifier compartment you should see the output package. The output package is where the phono speakers are connected to but this can be used to provide output to extention speakers. E1 to E7 tappings left and right provide outputs at different voltages/wattage. E1 left and right is the comon (or ground connection) E2 is the lowest tapping and E7 is the highest. Most people would connect extention speakers to E3 or E4 left & right with the comon connections of the speakers to one of the E1's.
There is also connections for 70 volt line speakers, these are used where long cable runs are needed and the speakers are then fitted with 70 volt drop down transformers to the correct wattage of the speakers. These are available from most good electroic suppliers such as R.S. or Maplins etc.
Regards
Alan Hood
ami-man
Uk
Hello, I actually made a
If you look at the bottom of the disk lifter arm, near the pivot, you will see a small switch - it's supposed to signal the end of the course and cut the power to the arm and if necessary, activate the carousel motor.
In your case that switch is dead - the power is not cut and the disk is constantly lifted. Repair or replace that end switch.
How do you set the Rockola 480 to free play?
For free play on Rock-Ola 480. Open your jukebox, on the right,you will see a large metal box marked Profit Setter. In this box are Sections A, B and D. In section D, you will see very small white buttons on a pink background. Push ALL of the buttons in section D to the left with a pen.It will play for free until changed. For money, put it back like it was. It will also play all songs automatically. If you wanna know that, e-mail to
[email protected]
I have a 1979 rowe ami jukebox model R65 when i
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B
Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B
Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe
...www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
[email protected]
My 1964 Rock Ola Capri
The movement of the arm is controlled by a cam; in that cam a pin should slide - in your case the pin got stuck in the channel of the cam. The mechanism should have been cleaned and oiled at least every 2 years. When you haven't done that the dust and dirt accumulated and practically have blocked the mechanism.
You will have to completely dismantle the mechanism, clean it with some paint thinner, dry it thoroughly, oil it abundantly and assemble it back to working order. Be careful and don't force, it's an old mechanism, the metal parts have become brittle with age.
BTW there is no reset button, that is just a service power button for the motor of the mechanism.
Rowe Ami R-80 imperial jukebox
Hello Andy,
Yes I know the 1976 Rowe Ami R-80 jukebox very well as well as most of the other Rowe Ami jukeboxes.
The turntable motor and the lighting work off of the 110 volt output from the power supply.
The other power voltages are connected to the power supply via the molex plug.
Pin 1 30VDC white/red
Pin 2 30VAC yellow/black
Pin 3 Common black
Pin 4 Ground gren/yellow
Pin 5 No connection
Pin 6 Common black
All the voltages are protected by circuit breakers.
I assume that you may be in the UK if this is the case here are my contact details.
Alan Hood (ami-man)
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
[email protected]
Hifi speakers
An ohm meter can determine only if the coil is open. For an 8 ohm speaker (impedence), the resistance measurement will be around 6 ohms. Why do you think these need reconing? Are they noisy?
Dan
It was working but there's no sound to my speakers from my naka michi RE - 3 vintage
If there is no sound coming from your speakers connected to the Naka Michi RE-3 vintage receiver, you can try the following troubleshooting steps:
1. Check Speaker Connections: Ensure that the speaker wires are properly connected to the appropriate speaker outputs on the Naka Michi RE-3 receiver and that they are securely attached to the corresponding terminals on the speakers. Verify that the connections are not loose or damaged.
2. Speaker A/B Selection: If your receiver has multiple speaker outputs or A/B speaker selection options, make sure the correct speakers are selected and enabled. Check the receiver's front panel or remote control for speaker selection buttons and confirm that the desired speaker configuration is chosen.
3. Volume and Mute: Ensure that the volume on the receiver is turned up to an audible level. Also, check if the receiver or remote control has a mute function enabled, and deactivate it if necessary.
4. Input Selection: Verify that the correct input source is selected on the receiver. Use the input selector buttons on the front panel or remote control to cycle through the available input options until you find the one connected to your audio source.
5. Test Different Inputs: Try connecting a different audio source (such as a different device or source) to the receiver and see if there is any sound output. This will help determine if the issue is specific to the current input or if it is a broader problem with the receiver.
6. Check Speaker Impedance: Ensure that the impedance of the speakers matches the recommended range for the Naka Michi RE-3 receiver. Using speakers with an impedance outside of the recommended range can result in low or no sound output.
7. Reset or Power Cycle: If none of the above steps resolve the issue, you can try resetting the receiver to its factory defaults or power cycling it by unplugging it from the power source for a few minutes and then plugging it back in.
If the issue persists after performing these troubleshooting steps, it may indicate a problem with the receiver's internal components or circuitry. In that case, it is recommended to contact a professional technician or Naka Michi customer support for further assistance or to schedule a repair.
