20 Most Recent
Rival Soft Serve 1.5 Quart Ice Cream Maker Questions & Answers
I followed the instructions exactly
No it shouldn't expand unless the conent volume was incorrect.
Have you followed the marks for reassembly on the cannister?
Assembling the Soft Server
1. Slide the Canister Collar upward onto the Canister until it locks. Make
sure it is positioned correctly; follow the indentations on the
Canister. (Figure 1)
2. Fasten Rubber Sealing Ring securely on the underside of the Canister
Lid. (Figure 2)
3. Insert the Screw into the Canister Lid Tube. (Figure 2)
4. Place the Dasher Assembly over the Canister Lid Tube. Turn it clock-wise
to make sure it locks in place. (Figure 3)
5. Place the Canister Lid with Dasher Assembly attached, inside the
Canister. Make sure the top of the Canister Lid aligns with the half
circle. It should fit in place when the half circle is aligned on the top.
(Figure 4)
NOTE: Make sure the Rubber Sealing Ring is assembled securely inside
the Canister Lid. The Rubber Sealing Ring must be thoroughly dried to
properly seal.
6. Place the transparent Top Cover over the Canister.
7. Gently lock the Motor Housing in place by pushing the Motor
downward onto the transparent Top Cover.
8. Securely lock down the 3 Locking Latches.
9. Select your designer Dispensing Tip (4 different designs) and attach
it over the Dispensing Opening.
To operate, the assembled unit must be placed in the
horizontal position when unit is first turned on and
kept in this position at all times for churning, pouring in
recipe and dispensing (as shown on the front cover of
the manual).
HOW TO USE YOUR SOFT SERVE ICE CREAM MAKER
Freezing your Canister
NOTE: The Canister must be kept in the freezer for a minimum of 24 hours
before each use.
1. Wash and dry Canister thoroughly prior to freezing.
2. For best results, wrap the Canister in a plastic bag and place upright
in the back of your freezer.
1. Slide the Canister Collar upward onto the Canister until it locks. Makesure it is positioned correctly; follow the indentations on the
Lid. (Figure 2)
Where can we acquire a new cover?
Unfortunately Rival doesn't make replacement parts available for their appliances. You can contact them directly at
Sites rival products Site However I haven't ever been able to get replacement parts through them.
I have found the 90% of canister style Ice Cream makers have the same size lids. In the past I have purchase West Bends Ice Cream maker lid and it fits perfectly on both my Rival ice cream maker as well as my Back to Basics model.
Here is a link to the parts on West Bends site:
IC10885 Ice Cream Maker
The lids is part number U66-2, and is only a couple of dollars from West Bend.
-Colleen @ Mending Shed
