20 Most Recent
Rowenta DE851 Iron Questions & Answers
My iron smells bad and transfers the smell to
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
The top plastic piece that runs the length of the
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
How do I get rid of the the stain from my rowenta iron?
We Use Debruce Polish on all our cooktops. Debruce also works on
stainless steel and polished granite, marble, porcelain, formica and
glass. DeBruce is non-toxic odor-less and eco-friendly. You can get
DeBruce on line at debrucepolish.com.
How do you fix a seal on a Rowenta Iron?
To try and seal the water leak will possibly render the appliance dangerous.
I would speak to Rowenta and ask the question. They may well extend the warranty if you suggest it wasn't used for say a few weeks after purchase etc.
