20 Most Recent
Rowenta DX-8800 Iron Questions & Answers
DX8800 iron
power light (red in handle ) comes on
Ur iron needs to check and adjust the THERMOSTAT SWiTCH for the heat!
Check also the THERMAL FUSE that might been blown and replace it w/ similar part!
U need to bring that iron to ur electronic technician if u can't dismantle it to adjust and replace the said parts!
hope that may help u out!
Yellow light comes on but iron does not warm up
You will have to check the continutiy of the heating element . Use a multimeter and open the connection port. Look at the terminals and take the test. it must shown full continutity, if not the element has failed.. remove cover and get full access to confirm. Good day
Nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
How do you fix a seal on a Rowenta Iron?
To try and seal the water leak will possibly render the appliance dangerous.
I would speak to Rowenta and ask the question. They may well extend the warranty if you suggest it wasn't used for say a few weeks after purchase etc.
