20 Most Recent
Rowenta Professional DX8800 Iron Questions & Answers
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
8/24/2013 5:57:48 PM •
Rowenta...
Answered
on Aug 24, 2013
How do I put water
the manual says to slide to left you can download manual at rowenta.com customer service on irons 8000 series
9/23/2011 4:22:47 PM •
Rowenta...
Answered
on Sep 23, 2011
I NEED A NEW ELECTRIC
Chances are you will only need to replace the end and that is fairly easy to do.Buy one from a local electrical or a hardware shop.It should come with instructions or you can Wiki How it.
8/6/2011 5:15:21 PM •
Rowenta...
Answered
on Aug 06, 2011
