20 Most Recent
Maax Pearl By CS42wh Pearl CS42 in White Questions & Answers
Tub goeson then turns off
This sounds like a bad motor. It sounds as if it is overheating.You will need the model number and brand of pump in order to find the correct replacement.rodus parts center888-521-6183
Rotten egg smell in bathroom closet?
I can't tell about your water supply from this posting. Is it possible you have iron or sulfur in your water that only shows up in the hot water? If so, you may not have drained the water heater often enough to prevent problems. Usually, draining it about every 6 months will do it. To drain the water heater, turn off the energy source (electricity or gas), turn off the inlet valve, and connect a water hose to the drain at the bottom of the tank. Open the drain ****. Some don't have handles and require a flat blade screwdriver to open them. Run the drain hose down the driveway so the hot water from the tank doesn't kill your lawn. By the time it reaches the street, it should be cooled off enough not to hurt anything. If it's been a while, you may want to weight down a trash bag at the end of the hose so the water and sediment coming out don't stain your concrete driveway. Let the water from the end of the hose dissipate over the trash bag. It takes about 30 minutes to drain a 40 gallon water heater. It goes faster to carefully open the overflow pop off valve to let air in while it's draining. When it's drained, close off the drain spigot, open the incoming water and when it is quiet again (full), turn the energy back on. You may have to relight the pilot or click the igniter until it flashes one time to let you know it's working. You should have hot water again in about 30 minutes. If the smell in the drain persists, some baking soda and vinegar flush will normally take care of that.
5/14/2019 1:12:24 PM •
Maax Home
Answered
on May 14, 2019
The tub is clogged with hair
Few plumbing issues such as
Dripping faucets. Running toilets. Leaky valves. Clogged bathtubs can be solved by our own trying few things.
1)Firstly lookout for what is causing blockage such as soap or hair inside the pipeline blocking water just pull it out from pipes.
2)Secondly use a plunger(Tool used by plumber to clear clog) pour some water in bathtub to cover the plunger block the overflow of water with rag.Place the plunger over drain pull up & down 5 to 6 times.
3)Lastly if still the clog is not cleared try out with snake a long flexible steel cable wound on a handle In a sink you just feed the snake down the drain, but on a bathtub you need to feed the snake down through the overflow plate opening. Start by feeding about 3 feet of the snake into the opening, turning it as you push it forward. You will feel some resistance as you work the snake through the trap under the drain, and the turning helps to move the head through the trap. The snake should either break up the clog by pushing its way through it, or your turning will hook the end of the snake onto the clog and you can pull it out.
After trying with above if still there is plumbing issue call sewer line repair services for help.
Grease Trap Services
10/26/2017 9:52:05 PM •
Maax Home
Answered
on Oct 26, 2017
