20 Most Recent
Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB - 102608-056-B - Biscuit Questions & Answers
The sensor won't detect water in the tub. When
I would first check that the suction intake has no obstructions. The next thing is to make sure that the jets are not pointed at the suction intake, there could be air getting into the system. You also need to make sure you have adequate water level.
My bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Rotten egg smell in bathroom closet?
I can't tell about your water supply from this posting. Is it possible you have iron or sulfur in your water that only shows up in the hot water? If so, you may not have drained the water heater often enough to prevent problems. Usually, draining it about every 6 months will do it. To drain the water heater, turn off the energy source (electricity or gas), turn off the inlet valve, and connect a water hose to the drain at the bottom of the tank. Open the drain ****. Some don't have handles and require a flat blade screwdriver to open them. Run the drain hose down the driveway so the hot water from the tank doesn't kill your lawn. By the time it reaches the street, it should be cooled off enough not to hurt anything. If it's been a while, you may want to weight down a trash bag at the end of the hose so the water and sediment coming out don't stain your concrete driveway. Let the water from the end of the hose dissipate over the trash bag. It takes about 30 minutes to drain a 40 gallon water heater. It goes faster to carefully open the overflow pop off valve to let air in while it's draining. When it's drained, close off the drain spigot, open the incoming water and when it is quiet again (full), turn the energy back on. You may have to relight the pilot or click the igniter until it flashes one time to let you know it's working. You should have hot water again in about 30 minutes. If the smell in the drain persists, some baking soda and vinegar flush will normally take care of that.
5/14/2019 1:12:24 PM •
Maax Home
Answered
on May 14, 2019
