20 Most Recent
Kohler 1107-R-0 ProFlex Bath Tub with Flange and Right Hand Drain Finish: W Questions & Answers
I need my bathtub resurfaced
For bath refinishing there are several companies out there that do that. My suggestion is to do a google/bing search and see what comes up in your local area.Rod
US Parts Center888-521-6183
How do I change jets in bathtub?
Do you wish to change the jets in the tub or just the trim?
If you just want to change the trim then you need to go the your local Kohler showroom and they can match up the correct replacements for you.
Rod
US Parts Center
How to Change White Water Whirlpool Tub Jet Hardware
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
I need a new air
You may find the air button you need on this site: http://www.uspartscenter.com/airbuttons-2.aspx
They have all the air buttons needed to fix your problem however, you will need to have access to the underside of the air button to change it out.
Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
I have a white water whirlpool tub that needs to
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Where to buy a Kohler air switch and air button?
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
I have a kohler jetted tub and i am having a
First, disconnect the air hosing from the back of the pump. Reconnect a new vinyl hose to the back of the pump, and blow into the other end. If your pump turns on/off by doing this, see 'A," if not, see "B."
A. The electronic switch in the pump is good, and there is a problem with the air switch or vinyl tubing. The vinyl tubing could be kinked or the air bellows has failed.
B. The electronic switch in the pump is bad, the capacitor is bad, or some other electronic part of the pump is bad. Buying a capacitor or an electronic switch is of course a cheaper fix than to replace the entire pump.
Hope that helps.
[email protected]
My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
you need to see if there is power to the pump 1st, there may be a switch somewhere thats not been switched on or it may have tripped out so check that. the air pressure switch maybe faulty or the plastic hose may have even come away from the switch.think of the basics 1st then look deeper, if you have power at the pump then it can only be the switch or worse case scenario a new pump.
you might have to remove the bath panel to gain access to the pump better?
kindly
Richie
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
