20 Most Recent Jacuzzi 6800-959 Nova 6 Whirlpool Bath 6'- White Questions & Answers
The Magic Touch system has been discontinued by Jacuzzi Whirlpool.
You will need a new air switch kit.
Rod
US Parts Center
888-521-6183
Jacuzzi 6800-959... | Answered on Feb 13, 2013
take the pump unions off the motor and look inside them at the tailpiece. You should see one black rubber o-ring inside each one. Make sure they are seated properly in the grove on the tailpiece and reinstall.
If they appear to be flattened on one side you may want to get some new # 0-49 o-rings and change them.
Once they are seated properly your pump unions will no longer leak water.
Jacuzzi 6800-959... | Answered on Feb 13, 2011
Contact the Dealer and seek qualified tech service. Risk of electric shock/***** You should not take the risk but have a QUALIFIED SERVICEPERSON perform the work.
Jacuzzi Home | Answered on Jun 29, 2019
There may be a video but you should be able to tell by looking at it too
big screw under tank holds valve on
toilet-dual-steelwire-drive-flush-valve-a2312-p2302-[1]-zgzkf31tgqefbd1nldh0nf0r-3-1.jpg
see:
https://reviewmotors.co/jacuzzi-dual-flush-toilet-repair-parts
Jacuzzi Home | Answered on Jun 14, 2019
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
Jacuzzi Home | Answered on May 23, 2019
Should be one on the motor and also check to see if there is a GFCi somewhere too. Could be around where the jacuzzi switch is.
Jacuzzi Home | Answered on Feb 10, 2019
try moving by hand they are calcified
Jacuzzi Home | Answered on Nov 04, 2018
the motor could be seased, can you get to back of motor to see if it's spinning
Jacuzzi Home | Answered on Sep 23, 2018
Jacuzzi 6800-959 Nova 6 Whirlpool Bath 6'- White Logo
5 questions posted
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
nova 6
  • Home
