20 Most Recent
Eljer Whirlpool In-Line Heater- 494-1550-00 Questions & Answers
Motor doesn't turn on.
Do you have the model number? A lot of these systems use a pneumatic tube to send air pressure to a switch. If you have one of those, make sure the tube is not loose or cracked.
2/20/2016 4:51:35 PM •
Eljer Home
Answered
on Feb 20, 2016
Air switch stuck
A sticky air button can be one of two issues.
- The Air Button can simply be worn out in which case it obviously needs to be changed. Measure the size of hole once it is removed and then you will know what size you need to reinstall.
- The inside of the Air Button may have some calcium built up inside where the button goes up/down. If you can get the center button up and removed then you can take some soft emery cloth and gently run around the outside edge of the button and the inside of the air button body. This will gently remove any calcium deposited there and allow the button to go up and down easily.
Rod
US Parts Center888-521-6183
7/17/2015 1:20:39 PM •
Eljer Home
Answered
on Jul 17, 2015
