20 Most Recent
Sharp Mx-2310u Color Copy/print/scan Questions & Answers
Maintenance TK1
TK1 Primary transfer unit counter has reached preset value or number.
To correct error, replace primary transfer belt/rollers. Enter calibration/diagnostic mode and reset counter.
Error code C1-14
Problem with the charger inside one of your drum cartridges. Inside the cartridge frame there's a charge sawtooth and grid which feeds and discharges voltage to your drum. This is a one-piece unit which gets swapped out from the maintenence kit. HOWEVER, IF your copier is at a high altitude, Sharp just published a bulletin saying you need to upgrade your Main Charge board.
H5-01
You have paper jam more than 5 times.
Press #*c* and enter simulation 14 and execute .ok
I have used Mx-2310U (copier, scan, print). It is
Dirty or broken sensors in the inside back of your machine that detect movement of your mylar transfer belt. A portion of the belt swings up and down for color printing. Or your belt unit may be broken or not installed properly
