20 Most Recent
Ricoh MP-301SPF Copier : MP301 Questions & Answers
Print complete skipped due to error?
Assuming this is installed on a local PC via a server. On the PC - Go to Control Printers (enter control printers from the run command) - Delete the printer - Click on another printer - Select Printer Server Properties - Click on drivers - Delete the driver. If it does not delete then restart the print spooler and then delete it. Once deleted add the printer again.
I had this happen and this was what I did to fix the issue. It seemed like the driver got corrupted or stuck in some odd setting.
Hope this helps.
Common problems with this machine
the most common problem on this device would be client/operator error, incorrect removeal of paper jams will result in a broken "fuser exit actuator" luckily this part is cheap and readily available
