20 Most Recent
Konica Minolta Bizhub C454 Color Copier Questions & Answers
Bizhub minolta 600 and 750
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
try this site for developer and drum as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
C210 error code
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though
Receiving error code C-E301
I just found this on the knowledge base it refers to this code when the hdd is replaced and internal data is different it may be a faulty hdd but there is a firmware in reference to this code.
Error C-E301 occurs for mismatching in the internal data as HDD is changed.
C-ED01 will be displayed as the mismatch in the internal data occurs as HDD is changed.
HDD Format will be necessary when this trouble is displayed.
firmware: A2X00Y0-F000-GPQ-65.exe
SMB
check if there's an error code in the completed queue.Also it would be helpful to know what kind of operating system is on your computer since MAC and Windows 8 are not that easy through SMB.Check if you shared the file on your computer to full acces rights
Hi
I need a help i hav error code C-8003 on konica Minolta B951. Please assist.
Thanks
Podtermistor wa?ka utrwalaj?cego nie
wykrywa wymaganej temperatury w ci?gu 30 sekund.
po rozpocz?ciu cyklu rozgrzewania; dlatego
kopiarka nie ko?czy cyklu nagrzewania.
• Temperatura wa?k?w utrwalaj?cych nie
osi?ga wymaganego poziomu nawet po
up?ywie ustawionego czasu podczas cyklu nagrzewania.
Sprawd?, czy lampka utrwalacza H1 zapala si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji W?., w razie potrzeby popraw lub wymie?.
Sprawd?, czy H2 w??cza si?, gdy g??wny
wy??cznik zasilania jest ustawiony w pozycji ON, i w razie potrzeby popraw lub wymie?.
Sprawd? instalacj? TH1 i TH2 i
w razie potrzeby popraw lub wyczy??.
Sprawd? dzia?anie TH1.
Usu? CN80 (4P), a nast?pnie sprawd?, czy rezystancja
na CN80-2 i -3 na termistorze jest
niesko?czona.
5
Sprawd? dzia?anie TH2.
Usu? CN81 (4P), a nast?pnie sprawd?, czy rezystancja
mi?dzy CN81-2 i -3 na termistorze jest
niesko?czona.
6
Sprawd? ci?g?o?? H1.
W razie potrzeby popraw lub wymie?.
7
Sprawd? ci?g?o?? H2.
8 Zmie? PU1 - -
9 Zmie? PWB-A
