20 Most Recent Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Questions & Answers
Kindly assist to reset admin password on bizhub c224
enter service mode Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/12/2019 7:14:07 PM • Konica Minolta... • Answered on Nov 12, 2019
Knoica Minolta Bizhub C224 fuzzy images but text is clear
the file may be corrupt try different files Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 6:28:42 PM • Konica Minolta... • Answered on May 07, 2017
Printer is printing pages with strips.
what color are the stripes Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2017 8:52:38 PM • Konica Minolta... • Answered on Mar 11, 2017
What is the administrator password bizhub c224
1234567812345678 or 12345678
8/8/2016 5:25:16 PM • Konica Minolta... • Answered on Aug 08, 2016
Blank print out
check the transfer belt and transfer roller Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/3/2016 3:19:04 AM • Konica Minolta... • Answered on Jul 03, 2016
Heater problam
replace the fuser unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/25/2016 4:37:26 PM • Konica Minolta... • Answered on Jun 25, 2016
How do i remove a job that says deletion error
4/29/2016 12:24:52 AM • Konica Minolta... • Answered on Apr 29, 2016
Printing copies crooked
prints ok from a different tray???????????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 11:12:23 PM • Konica Minolta... • Answered on Jan 18, 2016
Every other page is printing blank how do i fi it
does happen when copying does the demo page print ok does the meter count page print ok.? if you print in b/w is it ok? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 1:10:34 AM • Konica Minolta... • Answered on Jan 15, 2016
Print is not coming glossy it is mat finish
run gradation test, ensure fuser is at correct temp via media thick 1 thick 2 etc paper Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 4:41:37 AM • Konica Minolta... • Answered on Dec 29, 2015
How to clear the error
MFP Board Memory Board/1 Memory Board/2 EIF Board IC-414 Dual Scan Image Board One of the boards is bad. Recommended that you have a qualified Tech look at the machine. Also might need to have the firmware upgraded. via Secure KMBS web site you can not get. The code is a abort code! One of the followinf Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
10/31/2015 10:36:20 PM • Konica Minolta... • Answered on Oct 31, 2015
Service manual
you may find in internet just type model and you get it
9/29/2015 3:29:25 PM • Konica Minolta... • Answered on Sep 29, 2015
How do I with error C-DC30
Well you hit the "Jack Pot" That code means some one attempted to COUNTERFIET UNITED STATES currency!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!. Some one is in big trouble, There is not a thing you can do. You must get a KONICAMINOLTA Technician out to remove a special chip located inside the machine. It will be sent to KONICAMINOLTA then to the US SERECT SERVICE, since they protect US Money. Once a determination is made as to what happen. A new chip will be issued and new software will be up loaded. UNTIL THEN THERE IS NO RESET!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/21/2015 1:02:00 AM • Konica Minolta... • Answered on May 21, 2015
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite. --------------------------------------------------------------------------------------- Konica Minolta Error Codes & Solutions - http://www.kmcodes.com Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com Drum and Toner Chip Reset - http://www.chipreset.eu Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
8/21/2014 7:49:33 AM • Konica Minolta... • Answered on Aug 21, 2014
P8 error
its a warning p- errors tell you that a consumable is reaching its life such as fuser iu or transfer belllt
8/18/2014 1:53:54 PM • Konica Minolta... • Answered on Aug 18, 2014
Printing from InDesign on mac text is not consistent color, some letters paler than others
Check your separations preview, (>Window>Output>Separations Preview). Most likely the colors you have set up are not correct. You will need to identify the problematic colors and address them within your swatch palette. Very common problem.
12/26/2013 6:17:06 PM • Konica Minolta... • Answered on Dec 26, 2013
0answers
2answers
What is the p5, p9, p16 & L-4 error code mean in konica C754 ?
Replace the Black drum and developer unit (P9) (P16) and clean the IDC forward sensor(P5) (Requires removing the Transfer belt) L4 Black Drum Rotation well passed its life.
4/22/2024 1:19:49 PM • Konica Minolta... • Answered 2 days ago
O que posso fazer para remover o erro de codigo C-D252 na Konica Minolta C364 bizhub
English only on Fixya please. We are a North American website.
Error Code Pls help - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Jun 20, 2012 - CD252 (C-D252) code at start up. Solution CAUSE: The Controller 1 setting is enabled in Tech. Rep. Mode without the IC-409 (Fiery® ... fuser error code C252 May 7, 2014 Bizhub C451 bad print quality, no accurate color Jun 4, 2014 Error Code Bizhub 283 with C-D272 Mar 17, 2016 error code C- D251 bizhub C451 May 19, 2009 More results from www.copytechnet.com
Konica-Minolta bizhub C452 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+C452 Code: CD252; Description: No relay circuit boards for IC-412 mounting at IC-412 mount setting; Causes: MFP board (MFPB) Relay circuit boards (VI-505) . ..
3/3/2024 9:54:07 PM • Konica Minolta... • Answered on Mar 03, 2024
Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Logo
21 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
bizhub c224
  • Office Equipment & Supplies
