20 Most Recent
Konica Minolta Bizhub C360 Color Copier REPLACED BY BIZHUB C364 Questions & Answers
There ia a stripe appearing when I print with bizhub C364. How do you run a clean sheet
First thing to try. Open the front door and use your cleaning wand. This machine either has a cleaning wand located on each drum or the wand is located in tray two under a cover towards the front. Either way when you open the front door there should be a picture diagram on what to do.
Are any of your drum units at the end of life? Press utility/ check consumables. When that meter fills in with black its at the end.
Does it only appear when your are making copies for the Document Feeder? If so, lift the top so that you can see the 2 pieces of glass. There is a small strip on the left with a larger piece on the right. The line is coming from the smaller strip on the left. Clean it, getting all paper dust and what not off of it. I use Windex sprayed directly on the rag and then wiped clean.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
- Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
- Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
- Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
