20 Most Recent Sony RM-P352 Remote Control 147306921 Questions & Answers
You have this backwards. The applicable code would be in the URC, if it is compatible.
Sony Televison &... | Answered 2 days ago
if possible. reinstall your vcr code in your existing remote.
consider using another remote [ set to your vcrs code ] -- remotes sometimes low cost at dollar / thrift stores.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
Sony Televison &... | Answered on May 17, 2019
It will be difficult to make a Blu-ray player region free. Anyway, visit these sites, and see whether there is any information about this.
Sir
2time is over voltage error so please replace main board
thanks
Muhammad Nasir
Sony Televison &... | Answered on May 16, 2019
Hi Laurence, from what you describe, it would look like a power supply failure, like you say a loose solder
I recommend that you be careful with the manipulation of the source plate, since there may be loads in the capacitors
When you remove the back cover, locate the plate of the power supply and look for the input capacitor (s), to discharge them, then carefully check the solders that may be loose or cracked
Also note the low voltage capacitors, those on the secondary side of the source, that are not swollen or with the top open
After reviewing and resolving the source components, reassemble and test
In some models, you also have on the Main board, small subfuentes, try to locate and review them
If after doing all this, you do not have positive results, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Laurence, por lo que describes, parecer?a una falla de fuente de alimentaci?n, como tu dices una soldadura floja
Te recomiendo que tengas cuidado con el manipuleo de la placa de fuente, ya que puede haber cargas en los capacitores
Cuando retires la tapa posterior, ubica la placa de la fuente de alimentaci?n y ah? busca el o los capacitores de entrada, para descargarlos, luego revisa minuciosamente las soldaduras que puedan estar flojas o agrietadas
Tambi?n observa los capacitores de baja tensi?n, los del lado secundario de la fuente, que no se encuentren hinchados o con la parte superior abierta
despu?s de revisar y resoldar los componentes de la fuente, vuelve a armarlo y prueba
En algunos modelos, tambi?n tienes en la placa Principal, peque?as subfuentes, trata de ubicaras y revisarlas
si despu?s de hacer todo esto, no tienes resultados positivos, busca a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
Sony Televison &... | Answered on May 15, 2019
Hello Paula, do not have video, nor sound?
I send a link of support to the Sony user, on the model of your TV
If you follow all the steps and do not achieve positive results, get close to a specialized technical service
I hope you can solve the problem, comment if it was
Hola Paula, no tienes video, ni tampoco sonido?
te envio un link del soporte al usuario de Sony, sobre el modelo de tu televisor
Si sigues todos los pasos y no logras resultados positivos, acercate a un servicio tecnico espeializado
Espero puedas resolver el problema, comenta si asi fue
https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs/kdl-60ex645
try this
Using a RESET button
  1. Locate the RESET button on the camera. NOTE: ...
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
  4. After the camera reboots, the time and date settings menu will be displayed.
Apr 11, 2018
How to reset or initialize a camera back to original factory ... - Sony
https://www.sony.co.th/en/electronics/support/articles/00026099
If not, you need to send for repair
https://www.google.com/search?rls=com.microsoft%3Aen-US%3AIE-ContextMenu&ei=lzbbXIr-Foa2swX5-oHoBA&q=sony+cyber+shot+repair
Sony Televison &... | Answered on May 14, 2019
First turn on device to be programmed. Press what device you want to program (tv) hold it down and at the same time hold power button down. Wait for red light to shut off and come back on. When light comes on remove finger device button and continue to hit power button on & off until device shuts off. Then hit stop button on the bottom off remote.
A player with certain region code but not a region free player will only play discs from certain regions. A region 2 player can only play region 2 discs. So if you get a discs with certain region codes, you could get a disc copy without region code and then you could play it on your player. You could use Leawo DVD Copy to get this kind of copy.
I think it's more possible that the blank disc that you use to record the videos is not good enough. You could try some other blank discs such as Verbatim discs that are popular for its guaranteed quality. And make sure you choose the type of dvd that is designed for recording. You could also try Leawo DVD Creator which can burn videos to DVD without waiting for a long time of recording.
Maybe you could check this post "How to Convert 8mm to DVD" with detailed steps about turning the 8mm to digital files and burn the digital files to DVD discs.
Sony RM-P352 Remote Control 147306921 Logo
0 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
want make sony bdp s1700 blue ray player
  • Televison & Video
