20 Most Recent
Pulsar PXH225 Watch Questions & Answers
I've lost the owner's instructions
Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
Battery replacement
mcdevito75 here, First look for any for any notches or cut outs on the cover, there should be a cut out on the cover for the stem, at this point line up the cut out with the stem, place the watch on a sturdy surface, Table, counter top, make sure the watch is completely flat on this surface with the cystal (glass) faceing up, now place the palm of you hand on the crystal and with even pressure press down slowly and evenly, the back should snap on.
Pulsar watch s/n 462596 takes what battery
Best advice.
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
Or risk it
pulsar watch batteries - Amazon.com
https://www.amazon.com > pulsar-watch-batteries > k=p...
Duracell 370/371 Silver Oxide Button Battery, 1 Count Pack, 370/371 1.5 Volt Battery, Long-Lasting for Watches, Medical Devices, Calculators, and More.
Watch serial numbers
Model numbers and battery details etc. on Pulsar watches are normally stamped on the back plate but the serial numbers can sometimes be found on the inside of the back plate.
