20 Most Recent Rotel New Original RSX1058 Remote Control Questions & Answers
Hello Fayeshep,
They are indeed beautiful machines...!!
I looked for service and customer contact
See the top & bottom of the ROTEC AU page (below)
Good luck & happy hunting...
Rotel Australia Home Theater Hi Fi and Custom Installation
Rotel Televison... | Answered on May 20, 2017
Probably saying "no signal or signal too weak" - can't find satellite.
Televison &... | Answered 2 hours ago
I presume your'e talking about your TV receiver?
If all plugged-in devices (including the TV alone) do thhis, then suspect the TV.
First, the most obvious step is to check channel balance.
On my set, center balance is "0", while L<>R are -10<>+10.
If only one device, such as a DVD player or satellite decoder, check the AV cables, swap them out for another set, try other devices in same AV connector (or HDMI etc, depending on what setup you have).
By noting what works where (if any), you can narrow down the source.
If all else fails, your receiver may have an amplifier fault, loose wiring, or blown 'speaker.
If you're after a specific model, such as your TV make, yo'd probably have to go to where you originally bought them both.
If any universal will do, most supermarkets stock them these days.
Televison &... | Answered 3 hours ago
Hello Daniel, I sent you the link to download the service manual for your TV LG50PB690-V
I hope it will help you solve your concern
Greetings Franco Dosil
Hola Daniel te envio el link para que descargues el manual de servicio de tu TV LG50PB690-V
Espero te sirva para resolver tu inquietud
Saludos Franco Dosil
https://www.electronica-pt.com/esquema/func-download/28969/chk,72980d2bc94b4a9bfe1443a3609819cc/no_html,1
Televison &... | Answered 9 hours ago
Hello Daniel, ask, what kind of Leds did you use, did you replace the Leds strips that were wrong, for others of the same type and model or did you use generic strips or did you just replace all the LEDs, one by one and if you did this, you respected the Working voltage of each Led?
Another question, when you armed, did you put the soft plastic panel that is the reflector of the light of the LEDs?
I ask you all these questions in order to find the source of the problem and find the best possible solution
Also discuss the brand and model of your TV
I await your answers and some more comments about what you did
Hola Daniel, pregunta, que tipo de Leds usaste, reemplazaste las tiras de Leds que estaban mal, por otras del mismo tipo y modelo o usaste tiras de les gen?ricas o simplemente reemplazaste todos los Leds, uno por uno y si hiciste esto, respetaste la tensi?n de trabajo de cada Led?
Otra pregunta, cuando armaste, pusiste el panel pl?stico blando que es el reflector de la luz de los Leds?
Te hago todas estas preguntas para poder encontrar el origen del problema y encontrar la mejor soluci?n posible
Comenta tambi?n la marca y modelo de tu TV
Espero tus respuestas y alg?n comentario mas al respecto de lo que hiciste
Rotel New Original RSX1058 Remote Control Logo
1 questions posted
Top Rotel Televison & Video Experts
Raj Patel
deton8 von Splosion
Tom Chichester
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Televison & Video
Most Popular Question
rotel rbk d8100 power light blinking
  • Televison & Video
