The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
besides the fact that you have not given a phone number ( very unwise on unsecured web pages) we don't make calls
you can get that information by ringing the local service agent yourself
Most stepup/stepdown power transformers cannot supply the wattage necessary to power a vacuum cleaner. Unless the converter is the size of a toaster it won't be able to power the sweeper.
This type of vacuum is not designed to vacuum up sheetrock
dust or pieces of sheetrock. The dust from sheetrock is so fine it will clog the vacuum bag, filters and possible the motor
So change the bag, use an air hose to blow out the motor area and
the hoses make sure that air hose has in line filter to catch moisture
