20 Most Recent Sanyo 4.4 cu. ft Counter-High Refrigerator, SR-4433S Questions & Answers
MY FRIDGE WAS WORKING NORMALLY AND IT JUST STOP FREEZING
Your fridge most likely needs a refrigerant recharge , or a new compressor.
1/25/2018 11:00:17 PM • Sanyo 4.4 cu. ft... • Answered on Jan 25, 2018
0answers
Freezer panel not working
Sounds like someone tried to "defrost" it with a steak knife... The government employees in the highrise office buildings where I once worked used to do it all the time. The aluminum evaporator is nearly impossible to repair and the repairmen will tell you it's cheaper to replace it.
4/14/2014 12:21:20 AM • Sanyo 4.4 cu. ft... • Answered on Apr 14, 2014
SANYO SR-4433S Refrigerator part
SR-4433S door gasket
11/27/2013 9:17:43 PM • Sanyo 4.4 cu. ft... • Answered on Nov 27, 2013
0answers
2answers
Refrigerant line
how did this go for you? i am getting the same fridge for the same reason and wondering what you did with the freezer?
2/1/2011 11:43:56 PM • Sanyo 4.4 cu. ft... • Answered on Feb 01, 2011
Well i have a Sanyo SR-4433S 4.4CuFt Refrigerator
Hi, do you still have the parts? I just got a SR-4433S and I think it's missing some of the basic interior stuff like the crisper drawer, etc. I'll figure out all of what I need if you email me back and still have it: [email protected]
Thanks
10/22/2010 9:37:51 AM • Sanyo 4.4 cu. ft... • Answered on Oct 22, 2010
The refrig motor starts but the refrig is not
Hello,If the refrigerator is not getting cold, you need to answer some question.
1. check if the compressor is running.
2. Is the thermostat knob turn to the proper setting?if not reset it. then see if the compressor motor is running. The compressor is a football-sized case with no apparent moving parts,it's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of these components.
1. The compressor
2. Thermostat
3. The overload, relay, or Capacitor
4. The defrost timer
5. The condenser fan motor.
Thanks
6/21/2010 9:44:52 AM • Sanyo 4.4 cu. ft... • Answered on Jun 21, 2010
After i removed all the ice now its not cold at
Hi, The most critical question following a defrost is this ( if the fridge no longer cools/freezes )...What method did you use to remove the ice ? If you "chipped" it away via a knife or other means of "chipping" or "picking" the ice from the evaporator as opposed to allowing it to melt, I would immediately suspect a hole in the evaporator. If that is the case the fridge is toast. I mean in theory it CAN be repaired, but the cost would be impractical...unless you know a tech who can epoxy the evap and recharge the system with gas (R134A). If that is even legal where you reside, there are specific laws regarding "sealed system repairs" from state to state, province to province, country to country, so you'll want to check the laws/by-laws where you live. Of course you should insure the compressor is operating as that would be essential for the unit to cool as well. I have to say though, holes in the evaporator are the most common culprit for a manual defrost fridge not cooling...following a client "chipping" off the ice. Let me know if this answered you question. Thanks for visiting "fixya" for your fridge inquiry and good luck. macmarkus :)
4/17/2010 2:33:20 AM • Sanyo 4.4 cu. ft... • Answered on Apr 17, 2010
What kind of bulb I should use for sanyo
purchase an appliance bulb they are available at any hardware store. Ask an eployee in the appliance department and they will be glad to help
Dave
3/18/2010 6:31:35 PM • Sanyo 4.4 cu. ft... • Answered on Mar 18, 2010
2answers
I broke all glass shelf of refrigerator. Where can I get them all? T T
you must contact www.us.sanyo.com
3/8/2010 9:22:47 AM • Sanyo 4.4 cu. ft... • Answered on Mar 08, 2010
Refrigerators Logo
36 questions posted
Top Sanyo Refrigerators Experts
NOEL
NOEL
john h
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Sanyo Refrigerators
  • Sanyo Refrigerators
Most Popular Question
kind bulb use sanyo
  • Refrigerators
