20 Most Recent Sanyo SR-290 Compact Refrigerator Questions & Answers
2answers
Temp only works on high
Change the thermostat.
3/18/2014 4:22:28 AM • Sanyo SR-290... • Answered on Mar 18, 2014
Refrigerator only works on max
Usually when a compressor is running low on gas it will freeze up on any setting but if it only works on max the thermostat is most likely no good cheapest thing to do would be to order a new thermostat 90 present of the time it takes care if the problem
3/12/2014 1:44:34 AM • Sanyo SR-290... • Answered on Mar 12, 2014
User manuals
google user guide sanyo model sr-290 also the temp setting for 37 deg is 37 deg the numbers on the dial are only for reference you should get a thermometer for accuracy
12/1/2013 10:07:22 PM • Sanyo SR-290... • Answered on Dec 01, 2013
Need to find a door seal, gasket for a Sanyo MINI Refrigerator Model # SR69O8X
You have a couple of options. That said, measure your current gasket carefully to get a proper match. Seal the door properly or you are wasting your time as the seal keeps the temperature down. Sears PartsDirect: Sears PartsDirect offers official Sanyo compact refrigerator parts, including door gaskets. You can search for the specific part you need on their website. Remember to check the model compatibility to ensure a proper fit. Official Sanyo compact refrigerator parts ' Sears PartsDirect Parts Town: Parts Town also provides OEM Sanyo refrigerator parts, including the 8330331651800 REFRIGERATION DOOR GASKET. You can find this replacement part on their website as well Sanyo 8330331651800 REFRIGERATION DOOR GASKET ' Parts Town Official Sanyo SR-366S compact refrigerator parts ' Sears PartsDirect
2/13/2024 6:39:24 AM • Sanyo... • Answered on Feb 13, 2024
I HAVE A SANYO STAINLESS STEEL ECLIPSE SERIES REFRIGERATOR MODEL SR-4433S. I NEED TO REPLACE THE LIGHT BULB (125 V, 10 W. WHERE CAN I FIND THAT BULB?
What worked for me was a E12 size LED Light Bulbs 5W (50 Watt Halogen Equivalent) Color: Daylight 6000k. It looks great! I found mine on Amazon. Keep in mind you want the longest threat length possible because the light socket has around a 1/4" extension past the threats and I really need to tighten it quite a bit before it turned on. A 1-1/2" long bulb (not included threaded area) fit perfectly. If you plan to remove the thermostat/ switch, you must 1st remove the screw in the top back and then slide the thermostat assembly towards you and it will come free. 20240116_205250-u3qctebmy2slrx44owqjqkmy-d-0_0.jpg 20240116_205319-u3qctebmy2slrx44owqjqkmy-d-1_0.jpg
1/17/2024 5:12:53 AM • Sanyo... • Answered on Jan 17, 2024
2answers
Running water sounds when I plug in Sanyo mini fridge
That is probably the coolant being compressed and returning to liquid as it cools. Quite normal I would say.
11/19/2023 10:46:50 PM • Sanyo... • Answered on Nov 19, 2023
Hello, I have a Sanyo SR-4910M refrigerator and it stopped cooling!
bad temp sensor
3/12/2022 4:57:17 PM • Sanyo... • Answered on Mar 12, 2022
HOW CAN I GET A BULB FOR SANYO SR-141C?
Appliance bulbs can be purchased at any home improvement store.
3/9/2021 9:23:24 PM • Sanyo... • Answered on Mar 09, 2021
My sanyo slim beuty fridge dosnt coolingbut compressor works and little bit cooling???
try unplugging thermistor if gets cold replace it if no bad compressor or low freon
2/28/2021 7:59:59 AM • Sanyo... • Answered on Feb 28, 2021
I can't find a manual on the internet for the Sanyo model sr-8k fridge. Does anyone have one they can share? Would be much appreciated thanks.
I searched the internet and did not see a manual mentioned online. So, you may wish to contact vendors on the internet to ask if they have a manual. FIXYA is a free internet service and does not sell or mail products, and is designed for do it yourself (DIY) repairs. Examples: https://asianhomeappliance.com/home/detail_item/1919 https://www.carousell.ph/p/sanyo-sr-8k-2-7-cu-ft-personal-refrigerator-1012406429/?t-id=y8IePVwZ9Q_1592137710716&t-referrer_browse_type=search_results&t-referrer_request_id=zjJftFk9povRDeMo&t-referrer_search_query=Sanyo%20SR%208k&t-referrer_sort_by=popular https://www.carousell.ph/p/sanyo-sr-8k-2-7-cu-ft-personal-refrigerator-1012406429/?t-id=y8IePVwZ9Q_1592137710716&t-referrer_request_id=39Cbg_ZLkMBwQuZn https://ph.priceprice.com/SANYO-SR-8K-15611/ In the Philippines, Sanyo folded into Panasonic and Haier, so it is possible that they might provide assistance in that country, although I did not locate that model information on the internet. https://panasonic.net/sanyo/ph/cs/
6/14/2020 12:45:55 PM • Sanyo... • Answered on Jun 14, 2020
Need a thermostat for a small Sanyo referigerator model SR-368K PART NO IS.8334233C50101
https://www.made-in-china.com/cs/hot-china-products/Thermostats.html?gclid=EAIaIQobChMIibi_5Zyu5wIVF-DtCh3yogsREAAYASAAEgJC0vD_BwE https://www.alibaba.com/premium/thermostat_for_sale.html?src=sem_ggl&cmpgn=2069025735&adgrp=80538884390&fditm=&tgt=kwd-308834881422&locintrst=&locphyscl=1011086&mtchtyp=b&ntwrk=g&device=c&dvcmdl=&creative=374874816229&plcmnt=&plcmntcat=&p1=&p2=&aceid=&position=&gclid=EAIaIQobChMIibi_5Zyu5wIVF-DtCh3yogsREAAYAiAAEgL2uvD_BwE
1/31/2020 4:10:55 PM • Sanyo... • Answered on Jan 31, 2020
I bought a second hand Sanyo slim beauty model. For the first 5 days. It's was good.
what do you mean defrosting, do you mean getting hot as there is no cold air coming out, its not cooling is the freeze part working?
5/2/2019 10:38:31 AM • Sanyo... • Answered on May 02, 2019
2answers
Where can I get a new hinge as Sanyo is discontinued
Do you have complete model # of fridge?
2/18/2019 9:45:36 PM • Sanyo... • Answered on Feb 18, 2019
Sanyo standing freezer door fell off because bottom hinge pin broke
Replace hinge
2/18/2019 9:12:08 PM • Sanyo... • Answered on Feb 18, 2019
My Sanyo standing freezer door fell off as bottom door hinge broke.hiw can I fix it pks
You need to replaced the arm..
2/11/2019 6:17:12 PM • Sanyo... • Answered on Feb 11, 2019
Sanyo SR-290 Compact Refrigerator Logo
Popular Tags
10 questions posted
Top Sanyo Refrigerators Experts
NOEL
NOEL
john h
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Sanyo Refrigerators
  • Sanyo Refrigerators
Most Popular Question
temp only works high
  • Refrigerators
