20 Most Recent
Huawei EC5805 Crosswave Cricket broadband CDMA Wifi EVDO 800 MHz 3.1M Hotspot Wireless Modem Router Questions & Answers
Hi i want to change my password on my Huawei router. how do i reset it .
Thanks
To reset the password on your Huawei router, you can follow these general steps:
- Access the Router Settings:
- Connect your computer or mobile device to the Huawei router via Wi-Fi or an Ethernet cable.
- Open a web browser and enter the default IP address of the router in the address bar. The default IP address for Huawei routers is often "192.168.1.1" or "192.168.0.1". If these addresses don't work, you can check the router's documentation or look for the default IP address on the router itself.
- Press Enter to access the router's login page.
- Log in to the Router's Configuration Page:
- On the login page, enter the username and password. The default login credentials are usually provided on the router or in the documentation. Common default usernames and passwords for Huawei routers are "admin" for both the username and password fields.
- Click on the Login or Sign In button to proceed.
- Navigate to the Password Settings:
- Once you are logged in, find the settings section related to Wi-Fi, Wireless, or Security.
- Look for an option named "Password," "WPA Key," or "Pre-Shared Key" to change the Wi-Fi password.
- If you want to change the router's administration password (used to access the router's settings page), look for an option like "System," "Administration," or "Management" settings.
- Change the Password:
- Enter your desired new password in the appropriate field.
- Make sure to choose a strong and secure password that includes a combination of letters, numbers, and special characters.
- Some routers may require you to re-enter the new password to confirm it.
- Save the Changes:
- After entering the new password, look for a "Save," "Apply," or "Submit" button to save the changes.
- Click on the appropriate button to save the new password.
- Test the New Password:
- Disconnect any devices currently connected to the Wi-Fi network.
- Reconnect the devices to the Wi-Fi network using the new password to ensure it is working correctly.
How many GPON or 10G GPON ports does CGHF have?
CGHF board is an 16-port XG-PON and GPON Combo OLT interface board for
Huawei SmartAX MA5800 series OLT. It works together with the optical network unit (
ONU) to provide XG-PON and GPON access services.
16 XG-PON&GPON ports (SFP+)
Maximum split ratio 1: 256
Port rate: GPON upstream: 1.244 Gbit/s
GPON downstream: 2.488 Gbit/s
XG-PON upstream: 2.488 Gbit/s
XG-PON downstream: 9.953 Gbit/s
Rate mode: Asymmetric rate
Forwarding capability: 200 Gbit/s
Huawei B315s-22 router will not accept "admin" password after factory rest
If your Huawei B315s-22 router is not accepting the "admin" password after a factory reset, there may be a few possible causes for the issue. Here are some steps you can try to fix the problem:
- Check the router label: Make sure that the username and password listed on the router label are correct. It is possible that the label may have been damaged or misprinted, in which case you may need to contact Huawei or the retailer where you purchased the router for assistance.
- Check for firmware updates: Make sure that the router has the latest firmware installed. You can check for updates on the Huawei website or through the router's web-based interface.
- Check the caps lock key: Make sure that the caps lock key is not enabled on your keyboard, as the password is case-sensitive.
- Reset the router again: If the above steps do not help, you may need to try resetting the router again. To reset the router, locate the reset button on the back of the router and press and hold it for 10-15 seconds until the power light starts flashing. Then release the button and wait for the router to restart.
If none of these steps help, you may need to contact Huawei or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the router for any troubleshooting tips or recommendations.
Huawei y5p not responding
Here are some ways to fix such an issue:
Reboot your phone
This is the most common method to fix an unresponsive touch screen issue of your Huawei Y5p. Yes, rebooting your phone clears all processes running in the background and makes its memory free.
This process also makes the apps run smoothly. So, try rebooting your phone. This should fix your problem.
Not solved yet? No worries. You can try few more methods which we have mentioned below:
Boot into safe mode
Safe mode lets your Huawei Y5p boot to its original condition when your mobile was first switched on. Safe mode disables all third-party applications on your Android phone for a temporary basis.
You can get back to the original condition of your phone by just rebooting your device. Want to boot your Huawei Y5p into safe mode? Here's what you have to do:
Press and hold the Power Button > Menu will pop up > Press and hold the Power off symbol for 3 to 4 seconds > You'll see, "Reboot to safe mode" notification > Press Ok.
That's it. Now you are in safe mode. Check whether your touch screen works properly in safe mode or not.
If it's working well then you have a problem with some select third-party apps which you have recently installed on your phone. We suggest you uninstall those applications & reinstall them.
Factory Reset [ How to fix Huawei Y5p unresponsive touch screen isssue ]
You might have used this method previously for fixing some other issues related to your phone. With this method, all the data in your Huawei Y5p will be erased and your phone will be like a newly purchased device (PS: Just don't expect the same performance).
By Factory resetting your phone, all the data stored by third-party apps, and sometimes the setting of the device which was changed by such apps will be restored to default.
Before applying this method, remember that all data in your device will be permanently cleared. So back up your important files.
To factory reset your Huawei Y5p:
Open Settings > System > Advanced > Reset Options > Erase all data (factory reset) > Click on "Reset Phone."
In addition to this, you may be asked to enter your password at the end of this process & that's it. After performing a factory reset your phone's touch screen should have to work properly.
Regards,
Rachel Gomez
What is the CWMP? What's the function of it?
CWMP providing communication between a customer premises equipment and auto-configuration servers. It includes both a safe auto - configuration and the control of other CPE management functions within an integrated framework.
1)Autoconfiguration in which we creat files for different categories of CPE on the ACS.
2) Software image management when the ACS finds a software version update the ACS notifies the CPE to download the software image fgile from a specific location.
3) Data Backup in which the ACS can require the CPE to upload a configuration or log file to a specific location.
