20 Most Recent Rado Xeramo High-Tech Watch Questions & Answers
I'm unable to find information anywhere on this
This is just a personal suggestion that I have.
It sounds like you have a vintage Bulova watch and unless there is a watchmaker near you who deals with vintage watches (they are hard to come by!) you will have to rely on the internet but it could be a time consuming project.
What I would do, is go to www.google.com , type in vintage 14 kt Bulova, or 14 kt Bulova, or similar combination, and click on the IMAGE link (second tab at the top of page) and it will bring up every image on the internet of 14 kt bulova watches, etc. Look for the one that looks like yours and then go to the site that has that photo.. It might be helpful
Whatever you do, you have a good watch, Dont get rid of it as the gold is valuable, even if the watch does not work.
Please let me know if this is helpful at all. JKN
8/17/2010 3:52:16 AM • Rado Xeramo... • Answered on Aug 17, 2010
Need to remove 2 links
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
8/5/2010 3:28:53 AM • Rado Xeramo... • Answered on Aug 05, 2010
Forgotten password on mmc mobile memory card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
5/12/2010 11:53:19 AM • Rado Xeramo... • Answered on May 12, 2010
What battery goes in a rado centrix 54201303
Hi, Please call the maker of the watch (rado) to help determine the battery type. Or you might look in the manual for the watch if one was provided. Thank you.
6/9/2022 12:09:37 AM • Rado Watches • Answered on Jun 09, 2022
2answers
How can i come to know about the selling period of rado diastar?
I bought watch from online website mirraw check it out here http://www.mirraw.com/store/watches
1/28/2019 5:36:48 AM • Rado Watches • Answered on Jan 28, 2019
Time change for rado Dia star
google will help
11/25/2016 7:34:28 AM • Rado Watches • Answered on Nov 25, 2016
0answers
How can I set the time of this RADO Jubilee Esenza watch?
hay hi i found a pdf file with how to set time,date for all there watched link below no rar file. just pdf called manual.pdf hope it helps you. MEGA
5/22/2016 12:37:32 PM • Rado Watches • Answered on May 22, 2016
Rado Xeramo High-Tech Watch Logo
9 questions posted
Top Rado Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Rado Watch Expert? Answer questions, earn points and help others
View Most Popular
Rado Watches
  • Rado Watches
Most Popular Question
unable find information anywhere
  • Watches
