20 Most Recent
ASI CL51-15 Notebook Questions & Answers
How do i turn on wifi
Optional Intel PRO/Wireless 2200 (802.11b/g), upgradeable via mini-PCI adapter
It's not provided.
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
How to get into the bios
when you turn on your computer repeatedly press F2. Make sure this does not reach the Windows login page.
How to get the keyboard off my CL51-15 laptop?
ok laptops are extremely trickey to pull apart they have screws all over the place and hidden under things,just above the keyboard there is a panel with the power button etc, under the panel are the screws to remove the keyboard. to remove the panel it will simply pry off with a screw driver or there may be screws on the back at the bottom of the screen, i couldn't bring up a reliable pic of your laptop so this info may be useless if it is configured differently if so sorry
I need all the drivers
Hi
I can give you the site you can search by Product ID :
so you must do the following :
expand the
Start Menu -> right Click on
My Computer ->
PropertiesChoose the
Hardware Tab ->
Device Manager.
thin double click on the device and choose the
details Tab
copy the ID of device and past in
this site and start search...
I hope that helps you ^_^
Error loading operating system
May be the cause of OS files currept.
Plese follow the below stpe:
1. Boot up the system with OS cd.
2. At last there will be the two option (recovery and installation)
slect recovery for further steps.
How can I restart my asi computer back to b1
Are you trying to reboot the Computer or reinstall the Windows Operating System? For reboot, you can press and hold the power button for 5 to 10 seconds.
You will have to use the Windows XP Disc to reinstall the Windows. Please write to me with all the details to
[email protected] so that I can assist you better
Looking for drivers
Difficult to get I guess but, here's an easy way:
Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve them for you.
You can download this free tool from here, or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
