20 Most Recent Sharp R-254 Microwave Oven Questions & Answers
Hi, I have a Sharp R-254 microwave and the turn
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
11/15/2017 7:47:57 PM • Sharp R-254... • Answered on Nov 15, 2017
0answers
The light dows not work
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
3/10/2011 11:16:49 AM • Sharp R-254... • Answered on Mar 10, 2011
What is Sharp R-254 800 Watts Microwave
Sharp represents the Manufactures.. R-254 is the Model no. and 800 Watts represents the output power of the microwave.
6/9/2010 10:26:28 AM • Sharp R-254... • Answered on Jun 09, 2010
Display clock doesn't light
We regularly repair such control units for customers nationwide for $39.95 with a one-year guarantee.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
4/28/2010 5:11:24 PM • Sharp R-254... • Answered on Apr 28, 2010
0answers
Microwave user manual
Hi - You can download the manual from the link underlined in blue below:
sharp R-254 part 1
sharp R-254 part 2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
11/10/2008 8:23:26 PM • Sharp R-254... • Answered on Nov 10, 2008
Clock on Microwave
Normally on a Sharp, one of these key combinations will do it:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Let us know if this does not work.
8/10/2008 2:37:59 AM • Sharp R-254... • Answered on Aug 10, 2008
Loud noise
If you mean a loud buzz that cuts on and off as the oven works, it is probably the outer metal cover vibrating as the magnetron powers up and down. Try holding/ pushing/ poking the metal cover while the oven is working, if the noise abates or goes away, this is the problem.
You may get relief by simply tightening the screws securing the cover, if not, maybe a little careful insertion of a thin strip of cardboard or similar, at the point the vibration occurs, may dampen it. Good luck.
1/19/2008 1:23:45 AM • Sharp R-254... • Answered on Jan 19, 2008
Digital clock
you have to replace the control board id use it long as i could then get a new one as microwaves are getting so cheap its cheaper to get a new one as it is to fix
12/30/2007 5:15:56 PM • Sharp R-254... • Answered on Dec 30, 2007
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
3/16/2024 5:08:07 PM • Sharp Microwave... • Answered on Mar 16, 2024
Sharp carousel convection microwave model r9h10 user manual
I can send you the instruction manual for Sharp R-9H10. Please send your mail [email protected] is mine
1/19/2024 2:42:43 AM • Sharp Microwave... • Answered on Jan 19, 2024
Cannot reset Sharp R-4A52 Microwave, display keeps flashing.
Turn the microwave oven to the "On" position press "Stop/Clear" a few times -- the microwave should return to normal mode.
12/17/2023 2:58:27 PM • Sharp Microwave... • Answered on Dec 17, 2023
Sharp R-254 Microwave Oven Logo
25 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
microwave user manual
  • Microwave Ovens
