20 Most Recent Brasstech ''P'' Trap Kit - 3013 Questions & Answers
sounds like there may be some blockage in pipes. try to run a long snake through both drains or run all fixtures in bathroom and try plunging vigorously in tub and shower while running water. if nothing still, it may be possible that your underground plumbing is back graded or incorrect fittings and plumbing installation.
Brasstech ''P''... | Answered on Dec 01, 2012
If it stopped working suddenly check the GFCI to see if it tripped. If you think it may be a sediment problem go to a pool and spa store, they have cleaners that can help. In most cases salts won't cause it to stop working.
Brasstech ''P''... | Answered on Jun 11, 2009
what you would have to do is this measure how far in to the line you are figure out what wall pipe is in cut access hole to pipe cut pipe and clearout blockage replace pipe your best bet is to go pick up the 3 peices of plumbing first 1. pipe 2.conections
Brasstech ''P''... | Answered on Feb 19, 2009
https://www.boilerguide.co.uk/manufacturers/ideal/error-codes/ideal-f1-fault-code-explained
Plumbing | Answered 11 hours ago
The most likely component failure is the battery. It should last several years when properly maintained and desulphated.
When properly installed the pump only runs when theres a failure with the primary pump. So it should last indefinitely.
Plumbing | Answered on Oct 08, 2019
Check this out on u tube
Plumbing | Answered on Oct 03, 2019
To modify the pressure:
· Start the pump.
· If the SET LED blinks, hold key + down until the SET LED
remains on.
· Then press keys + or - to modify the pressure value
Plumbing | Answered on Sep 27, 2019
check underneath to tighten it
Plumbing | Answered on Sep 26, 2019
There are lot of tools used by professionals for plumbing. I don't find any reason to buy all of them.
So, at first decide which tools you need or for which specific tasks. If you can figure out which tools you really need then check your local tools shop or you can buy tools from online also.
Buying tools didn't solve your plumbing problem, you have to have required skill to use those tools and knowing basic plumbing.
Thanks.
Plumbing | Answered on Sep 25, 2019
TAKE IT OFF A FLUSH FROM THE BACK END
Plumbing | Answered on Sep 24, 2019
TRY TURNING ON THE WATER A LITTLE THAT USUALLY POPS THEM UP
Plumbing | Answered on Sep 23, 2019
Take is apart and clean it, lubricate the parts. Replace plunger, washers and o-rings.
https://www.youtube.com/watch?v=qYiF3y5f9yI
Plumbing | Answered on Sep 16, 2019
Ebrud730:
There is a hex-nut configuration at back of the handle of your sprayer where the hose enters the back of the sprayer handle. You can use a wrench to unthread the back cap and hose and remove them. You will have full access to all of the goodies inside of the sprayer handle at that point. pull the parts out and clean them with a rag that has some tooth to it (such as terry-cloth) and wipe off the WD-40 and liquid wrench (they will adversely affect your "O-rings") clean off the o rings and plunger and re-assemble the sprayer. You may have to go to Home Depot or Lowes to get replacement "O-rings" to stop the leakage.
Plumbing | Answered on Sep 15, 2019
No, you cannot.
Plumbing | Answered on Sep 14, 2019
Brasstech ''P'' Trap Kit - 3013 Logo
3 questions posted
Top Brasstech Plumbing Experts
Andrew Bugbee
Tom Chichester
Are you a Brasstech Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Brasstech Plumbing
  • Brasstech Plumbing
Most Popular Question
large whirlpool tub in mb 1st floor
  • Plumbing
