20 Most Recent Rolex Explorer II 16570 Wrist Watch Questions & Answers
Rolex did make this watch. Very nice watch. If you want to know what its worth - for to Bobs Watches on the web do a search there.
Rolex Explorer... | Answered on Oct 08, 2018
I would expect Rolex to have a record of all their watches and if you contact your nearest dealer, they should be able to help you.
You can find a store guide on their web site "rolex.com"
Rolex Explorer... | Answered on Aug 08, 2017
The noise and the vibration is coming from the winding rotor loose axle. There can be two causes for it:
1) the rotor axle, bridge and setting (fixing) spring is getting loose. This will be quite easy repair as all it takes is to tighten all screws and replace or tighten setting spring.
2) rotor axle is worn, so, consequently the bridge and the setting spring as well. In this case the rotor axle must be replaced by the new one and re-bushed into the bridge and the new setting spring must be fitted. This takes quite a lot of work and new parts as well.
Can not tell you about the costs, but Rolex repairs has never been cheap. In the U.K.about a year ago I did the repairs as described in chapter 2 and customer was charged £195.00, parts inclusive, and it was cheap by the Rolex standards.
Do not forget to rate, please.
Rolex Explorer... | Answered on Aug 29, 2012
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Rolex Explorer... | Answered on Sep 06, 2010
Go to www.rolexrepairs.co.uk there are contact details so you can talk with a Rolex trained watchmaker.
Rolex Explorer... | Answered on Aug 19, 2010
The price will vary greatly depending on age and condition. A brand new one costs about $5500.
Rolex Explorer... | Answered on Jul 15, 2010
mcdevito75 here, Sounds like your watch is showing a different time zone, refer to your owners manual or vist a locl jeweler for adjustment on timeing, setting your watch. Your watch may be set up to show different world time zones, if so, you may have hit a button and now your watch is showing time in a different time zone as an example London / New York.
Rolex Explorer... | Answered on Jun 29, 2010
It should be the 3rd position on the crown: 1st date, 2nd hour, 3rd time zone. And don't take it to a "jeler" like jamison said. If you cannot do this watch is fake.
Rolex Explorer... | Answered on Feb 20, 2010
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Rolex Explorer... | Answered on Feb 04, 2010
First- unscrew the crown. Then pull it out to the first click. In this position you can adjust date by turning the crown. When date is set, pull the crown further out (second click). This position is for time setting. Adjust the hands to desired time.
Push the crown back in and screw it on tight.
That's all.
Rolex Explorer... | Answered on Aug 05, 2009
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Rolex Explorer... | Answered on Jul 09, 2009
Hi Sggann. You shouldn't need to wear a Rolex automatic watch all the time for it to be kept wound, and you can in any event manually wind it 30 times to top-up the mainspring. You don't say how long you've had the watch, or when or if you've serviced it, but it sounds like it might need a clean and service; this replaces the oils which can thin out over time and effect the timekeeping of the watch, and the watch will be tested to ensure it runs well. Get Rolex to do it, unless you know a capable and accredited watchmaker - it's not cheap (around £250), but then again the watches cost a lot! All the best; Eagle58
Rolex Explorer... | Answered on Jul 05, 2009
Hi rajbhaduri. There's a complete guide to mastering these amazing watches at http://www.koniaris.com/rolex/
Enjoy! Cheers; Eagle58
Come on man, go buy a truly Rolex, not a fake! What a shame!!!
Rolex Explorer... | Answered on Mar 18, 2009
If it still under warranty take it back to rolex, other wise take it to an indpendent watchmaker they should be able to fix it for a small fee. The watch probably doesnt need a service yet if it is new.
Rolex Explorer... | Answered on Jan 06, 2009
Rolex Explorer II 16570 Wrist Watch Logo
39 questions posted
Top Rolex Watches Experts
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
View Most Popular
Rolex Watches
  • Rolex Watches
Most Popular Question
ad purchased brand new explorer ii 16570
  • Watches
