20 Most Recent
Pride Mobility Products Sonic Scooter By Pride Mobility Questions & Answers
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
Batteries don't appear to be
Actually this are 12 volt batteries.There are two such batteries, so the volt should be 24 volt.-----
The possibility is that either battery is faulty or the charger is faulty.-------
Batteries are new, so it indicates towards faulty charger.--------
But in some cases its noticed that new batteries come faulty.Not always but in some cases its seen.
Check the batteries separately with meter also inspect the battery charger with meter.It will point towards the cause of problem.---------
This should help.Thanks.Helpmech.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
