20 Most Recent Vector VEC056 MAXX Power Inverter Questions & Answers
On inverters with four terminals what will happen if only one set was wired
If there are four outputs then hooking up one set won't hurt a thing. Make sure they are not a pair of input and a pair of outputs.
7/13/2014 1:27:51 AM • Vector VEC056... • Answered on Jul 13, 2014
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
2/27/2010 4:56:20 PM • Vector VEC056... • Answered on Feb 27, 2010
My vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
8/15/2009 2:09:30 AM • Vector VEC056... • Answered on Aug 15, 2009
2answers
Puff of smoke
Have you looked at the fuses within? I have two in the one I am trying to fix!!
Peter
3/3/2009 10:53:48 PM • Vector VEC056... • Answered on Mar 03, 2009
When wiring reversed polarity. now it not work. is there fuse in the unit some where?
Fuse is there, but more damage is suspected. Transistors damage easily and capacitors will short when subjected to reverse polarity.
1/1/2016 11:44:39 PM • Vector... • Answered on Jan 01, 2016
4answers
What can i hook up with 1500 watts
15 100watt bulbs
1/4/2015 3:45:23 PM • Vector... • Answered on Jan 04, 2015
Durite inverter
If the unit doesn't have an external fuse and it doesn't reset itself after an overload, it possibly has an internal (onboard) fuse that needs replaced. Possibly de-soldered and re-soldered...
2/2/2014 5:57:01 PM • Vector... • Answered on Feb 02, 2014
0answers
Tvec034 manual
Be the first to answer 9/3/2013 5:17:14 AM • Vector... • Posted on Sep 03, 2013Be the first to answer
I have a Sport Spot 15 million Power Series power
Go to.. http://documents.dewalt.com/documents/English/Instruction Manual/Vector/VEC190POB.pdf This is the owners manual for this light
6/24/2012 5:00:14 PM • Vector... • Answered on Jun 24, 2012
I need the circut board for my vector VES 127BW I
Try partstore.com
5/14/2011 10:05:54 PM • Vector... • Answered on May 14, 2011
Have a vector model
The cost to ship lead-acid batteries is really cost-prohibitive. I suggest going to your local Batteries-Plus store for the replacement.
11/7/2010 3:08:19 PM • Vector... • Answered on Nov 07, 2010
Hello i havi solderd in
www.donrowe.com/user_guides/vector/vector_d_models.pdf
www.hemispheregps.com/.../vector/875-0076-001_VectorManual%20053101_.pdf
Without a schematic diagram, and troubleshooting procedures, it is very very hard to service such a piece of equipment such as this. I get a few of these over a year and invariably, it is the Output Devices, that fail, and along with this usually the CPU,or "Brain" gets "Fried" as well.
You have to treat this in two parts, the Input and the Output, the only way to repair is to isolate these two sections, then troubleshoot and repair the Input section, FIRST, once this is all going correctly, then, the Output section, is attended to if applicable, often it is an "Overload" on the Output side that causes a failure on the Input side, so many many times we have two "Faults" that need to be attended to, if only one is repaired the unit will soon fail again.
One simply MUST obtain a service manual, to be able to have any chance at a repair. The best way to do this is to contact the manufacturer, and ask for one. Then you will have a schematic diagram, to work from.
7/31/2010 6:05:51 PM • Vector... • Answered on Jul 31, 2010
I have a 400 watt vector inverter prower on board
yes if this is close to mine there is a cover over 2 feuses on the back
7/5/2009 9:32:36 PM • Vector... • Answered on Jul 05, 2009
Need new Battery
Had a seller on E-Bay respond with a Vector service # where I found a local dealer through and ordered the part.
2/19/2009 9:32:00 PM • Vector... • Answered on Feb 19, 2009
Vector VEC056 MAXX Power Inverter Logo
12 questions posted
Top Vector Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Electronics - Others
Most Popular Question
inverters four terminals will happen
  • Electronics - Others
