20 Most Recent Vector MAXX SST 500 Watt / 1000 Peak Watt Power Inverter AC / DC with Carry Questions & Answers
Will not turn on
sounds to me like there is a dead short somewhere in the system, I would take it to an electrical appliance repair shop and they can fix it. If there are none in your town then look on the internet for one in your state so you won't have to send it very far to get it fixed.
7/16/2010 3:07:53 AM • Vector MAXX SST... • Answered on Jul 16, 2010
When wiring reversed polarity. now it not work. is there fuse in the unit some where?
Fuse is there, but more damage is suspected. Transistors damage easily and capacitors will short when subjected to reverse polarity.
1/1/2016 11:44:39 PM • Vector... • Answered on Jan 01, 2016
4answers
What can i hook up with 1500 watts
15 100watt bulbs
1/4/2015 3:45:23 PM • Vector... • Answered on Jan 04, 2015
Durite inverter
If the unit doesn't have an external fuse and it doesn't reset itself after an overload, it possibly has an internal (onboard) fuse that needs replaced. Possibly de-soldered and re-soldered...
2/2/2014 5:57:01 PM • Vector... • Answered on Feb 02, 2014
0answers
Tvec034 manual
Be the first to answer 9/3/2013 5:17:14 AM • Vector... • Posted on Sep 03, 2013Be the first to answer
I have a Sport Spot 15 million Power Series power
Go to.. http://documents.dewalt.com/documents/English/Instruction Manual/Vector/VEC190POB.pdf This is the owners manual for this light
6/24/2012 5:00:14 PM • Vector... • Answered on Jun 24, 2012
I need the circut board for my vector VES 127BW I
Try partstore.com
5/14/2011 10:05:54 PM • Vector... • Answered on May 14, 2011
Have a vector model
The cost to ship lead-acid batteries is really cost-prohibitive. I suggest going to your local Batteries-Plus store for the replacement.
11/7/2010 3:08:19 PM • Vector... • Answered on Nov 07, 2010
Hello i havi solderd in
www.donrowe.com/user_guides/vector/vector_d_models.pdf
www.hemispheregps.com/.../vector/875-0076-001_VectorManual%20053101_.pdf
Without a schematic diagram, and troubleshooting procedures, it is very very hard to service such a piece of equipment such as this. I get a few of these over a year and invariably, it is the Output Devices, that fail, and along with this usually the CPU,or "Brain" gets "Fried" as well.
You have to treat this in two parts, the Input and the Output, the only way to repair is to isolate these two sections, then troubleshoot and repair the Input section, FIRST, once this is all going correctly, then, the Output section, is attended to if applicable, often it is an "Overload" on the Output side that causes a failure on the Input side, so many many times we have two "Faults" that need to be attended to, if only one is repaired the unit will soon fail again.
One simply MUST obtain a service manual, to be able to have any chance at a repair. The best way to do this is to contact the manufacturer, and ask for one. Then you will have a schematic diagram, to work from.
7/31/2010 6:05:51 PM • Vector... • Answered on Jul 31, 2010
I have a 400 watt vector inverter prower on board
yes if this is close to mine there is a cover over 2 feuses on the back
7/5/2009 9:32:36 PM • Vector... • Answered on Jul 05, 2009
Need new Battery
Had a seller on E-Bay respond with a Vector service # where I found a local dealer through and ordered the part.
2/19/2009 9:32:00 PM • Vector... • Answered on Feb 19, 2009
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Vector MAXX SST 500 Watt / 1000 Peak Watt Power Inverter AC / DC with Carry Logo
Popular Tags
2 questions posted
Top Vector Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Electronics - Others
Most Popular Question
will not turn
  • Electronics - Others
