20 Most Recent
Sharp R-1505 Microwave Oven Questions & Answers
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Heat: I placed a microwavable food product in my
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sharp carousel microwave, Model Number R-1505F, is not running
This
is usually caused by either a bad bottom door switch or a loose bottom door switch
mount, which are pretty simple problems to fix.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.See
http://www.microwavedisplay.com/doorsw.txtIf you only need a
switch, you can order a universal type here for $5 postpaid.
We have
the service / repair manual for this model and have uploaded
it to our
site here for free download to help you.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
How do I clean the inside of the microwave? It is
DO NOT use SOS pads! They are made of STEEL WOOL and will remove the protective finish inside the oven cavity. Without the protective coating, the microwave can arc internally and ruin the magnetron. Use the green scrub pads you find in the dish detergent section of your local grocery store. They are considered non-abrasive. Use the green scrub pads along with a non-abrasive cleaner such as Soft-Scrub or 409. Wipe clean with a fresh water and dry with a clean cloth.
Sharp r-1505 microwave. several segments in
Sharp had "issues" with that board (connector cable fail). That was back in 2002. Give them a call and see if they will send you a new control board (part # CPWBF070MRU0) All of the 0's are zeros.
If not, look at that ribbon connector where it's kinked, and you'll see a spot that should be repaired, ie broken wire.
Good luck with the phone call. Refer them to bulletin # MW-166.
fil
My Sharp R1505 Microwave's LED display is
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from
Encompass here.
Or you can get yours repaired for $39.95. Details here.
We're happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
I have a Sharp R-1505
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
