20 Most Recent
Samsung UN50EH5300 - 50" 5 Series LED-backlit LCD TV - UN50EH5300FXZA Questions & Answers
I have a 50 inch Samsung Smart TV UN50EH5300 that went dead...so I replaced the voltage supply board and it came on sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
11/5/2019 4:45:18 AM •
Samsung...
Answered
on Nov 05, 2019
How do I fix my 50"Samsung led t.v?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/17/2016 9:22:37 PM •
Samsung...
Answered
on May 17, 2016
Movie picture does not fill screen
If it's an older movie it will not fill the screen . It was never meant to play on a wide screen TV so the only thing you can do is use the zoom and stretch features on your remote. You may not like the results.
2/10/2016 12:22:42 AM •
Samsung...
Answered
on Feb 10, 2016
What caused video failure?
12/6/2015 1:40:01 AM •
Samsung...
Answered
on Dec 06, 2015
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
