20 Most Recent
Sharp R-220BW Microwave Oven Questions & Answers
Can't figure out how to defrost something.
> If for some reason you don't still have your manual, here are ways to get one:
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual. You can download it free.
If it's not there, you should be able to order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
- William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
My sharp microwave r-220bw is
Hi -
You just need to set the clock and you should be able to use the microwave again.
1. Press STOP/CLEAR. The 88:88 should stop flashing and be replaced by a flashing :
2. Press TIMER/CLOCK
3. Enter the time in 12 hour format using the number keys, e.g 8 3 2 for 8:32pm (or am)
4. Press TIMER/CLOCK again
I can't honestly remember whether you need to press TIMER/CLOCK before setting the time, so if it doesn't work after you've done the above, switch the power off and back on, and do it again without pressing TIMER/CLOCK before entering the time.
2. Enter the time in 12 hour format using the number keys, e.g 8 3 2 for 8:32pm (or am)
3. Press TIMER/CLOCK
This should be all you need to do to use the microwave again. If the 88:88 doesn't stop flashing when you press STOP/CLEAR you may have a defective control pad or PCB.
Hope this helps. If you need further assistance you can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
My microwave oven sharp r-220, it doesnt give heat
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Need a new sharp waveguide cover
The best place to order Sharp parts is
Tritronics.
Have your model number handy.
Microwave won't work
The first thing to try
is a "hard reset". Unplug it from the power line for a minute, plug it
back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help you and we'd appreciate your
Microwave ovens
Can't tell you much about your little rectangle, but sparks can result from left over food particles that got carbonized, and a good cleaning might get rid of it, unless you like looking at the sparks(I heard you shouldn't stare at a microwave while working though, washing machines are safer).
make sure you unplug it while cleaning or doing anything else, those micros are dangerous as hell.
Take care
Bake
back in the 1980s and early 90s there were cake and cookie mixs designed for microw use, you would have to go to market and read lables to be sure
Sharp selling bad microwaves
paddy paddy paddy i want i want, bet you were spoiled as a child,
never continue to use a microwave that sparks, you can only do more damage to the appliance and maybe even worse
is this sparking when you use it under normal conditions, place a plastic bowl with cold water in and see if it sparks then, if not then is it something you have done, i assume you know what you can not put in a microwave
if sparking occurs anyway, and its only 6 months old, is it under guarantee, then its simple, send it back and ask for free replacement
SHOUT AT THE RIGHT PEOPLE DON'T WASTE TIME ON HERE
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
