20 Most Recent Kohler C3-200 K-4709-96 Biscuit Elongated Toilet Seat with Bidet Fun Questions & Answers
K-4709 toilet seat with bidet
I would check to see if you in fact have power going to the pump itself,, you might just have a bad water pump or a bad switch. use a volt meter to trace voltage flow.
c...
1/29/2011 7:22:11 AM • Kohler C3-200... • Answered on Jan 29, 2011
Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
8/23/2009 6:02:20 PM • Kohler C3-200... • Answered on Aug 23, 2009
I have a 1987 kohler comode. does not flush all the way down
line pluged up.
7/1/2009 2:57:27 PM • Kohler C3-200... • Answered on Jul 01, 2009
Toilet does not flush strong enough to take down feces in bowl
You need to do 2 things. Take the lid off and check that the water level is up to the fill line, if it is you need to adjust the flapper. If it's not back the screw out on top until it is. Their should be a cylindrical piece of foam on the chain going to the handle. You need to pull off the retainers and move that foam closer to the flapper thus dumping more water in each flush.
Please rate this solution-
3/20/2009 7:16:49 PM • Kohler C3-200... • Answered on Mar 20, 2009
I have a Kohler commode about 1 1/2 yrs old. When
Does it have bll **** on it?That means a long brass rod with a ball on the end.If it does then gap it with both hands and with the hand next to the ball push down a little ways and keep doing this until the water stops running.If you have a fluidmaster brown or black the little wire on the side of you will see a little metal piece squeezed it and down and the should stop.
3/15/2009 3:43:14 AM • Kohler C3-200... • Answered on Mar 15, 2009
HOW TO REPLACE WATER HEATER COIL OF V GUARD WATER HEATER
The video given below may help you.
8/16/2014 11:29:27 AM • Kohler Water... • Answered on Aug 16, 2014
Ariston troubleshooting
On all fixtures? Just one fixture?
7/15/2014 10:36:07 PM • Kohler Water... • Answered on Jul 15, 2014
How to replace a gas waterheater
1) Copy following link for step-by-step replacing gas water heater:http://waterheatertimer.org/How-to-install-gas-water-heater.htmlhttp://waterheatertimer.org/pdf//Which-is-best-gas-water-heater.pdf2) Add a comment Feb 2013 for more help as needed. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/26/2013 10:47:29 PM • Kohler Water... • Answered on Feb 26, 2013
Where can I get a Service Manual including error codes, of HITACHI Package unit RUA-30AT3S?
I am not sure they are available to non Hitachi service centres. https://documentation.hitachiaircon.com/glb/en/pac/rua-at3s
3/17/2024 4:06:16 PM • Water Heaters • Answered on Mar 17, 2024
VAILLANT ECOTEC PLUS 831 BOILER , with an error code of F79, which is not in the handbook, its not working at the moment, already had a local plumber out, who didn't know a lot about F79 code
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
2/12/2024 9:14:32 PM • Water Heaters • Answered on Feb 12, 2024
2answers
Envirotemp water heater
Do I need to insulate this heater out in the shed? Freezing temperatures
2/6/2024 11:45:03 AM • Water Heaters • Answered on Feb 06, 2024
Remeha avanta plus combi problem
Call a engineer
1/11/2024 7:52:09 PM • Water Heaters • Answered on Jan 11, 2024
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
12/26/2023 4:41:20 PM • Water Heaters • Answered on Dec 26, 2023
How to replace digital thermostat on Amtrol boilermate to a manual thermostat
Where does the tube sensor go
12/23/2023 12:54:29 AM • Water Heaters • Answered on Dec 23, 2023
10 year old Richmond 40 Gallon water heater, cannot move knob to ON/OFF or Pilot. Pilot light is out.
call plumber to replace gas valve, it may cheaper replace water heater. gas valve is not DIY
12/1/2023 6:48:46 PM • Water Heaters • Answered on Dec 01, 2023
My boiler doesn,t always switch off when programe is off
test for sticking relay faulty circuit board or faulty stat
10/28/2023 4:42:20 PM • Water Heaters • Answered on Oct 28, 2023
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock. Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
10/17/2023 2:53:24 PM • Water Heaters • Answered on Oct 17, 2023
Kohler C3-200 K-4709-96 Biscuit Elongated Toilet Seat with Bidet Fun Logo
9 questions posted
Top Kohler Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Kohler Water Heaters
Most Popular Question
toilet not flush strong enough down
  • Water Heaters
