20 Most Recent
Sharp R-316FS Microwave Oven Questions & Answers
Hello
My name is Mohamed.
I have
Door catches.
One of the latches may be damaged or
misaligned and is not lifting the other latch clear of the housing.
Remove from any power source, remove the cover of the cabinet.
Slacken off the clamp mechanism and ease the clamp over the guide to
allow the door to open. When the door levers are in place, the door
may be easily adjusted by slackening off the screws that clamp the
door catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
SHARP MICROWAVE R-310AW DISPLAY GOING OUT
Remvoe the panel and see if there is any infestataion of cockroaches or insects into the display panel. if so remove and clean the bord properly using some petrol and a brush. make sure you do not damage the display or the board. Now check for any dry solder on the printed board , if bad do a touch up solder on the suspected dry points. check for the filter capacitors of the power supply and the regulators.
Check votage to the mP , solder the crystal and check.
Display not working (no dispay)
We regularly repair microwave displays & control
units for
customers nationwide $39.95 with a one-year guarantee.
Be sure to mention your full model number.
No Power
Remove cover. Check that the fuse is good, if it is good, check power from power supply to main board.
All appears to work...fan/light/ display....but no
You have burned micro switches in the door safety interlock system. I have answered this question dozens of times here - i am surprised this answer didnt come up when you searched your problem.
There are two reasons for the heat to not come on when everything else works ... three actually, the third is expensive.
1) the capacitor has failed - dont try to service this unless and until you understand the dangers associated with this repair.
2) burned safety door switches
3) failed magnatron (they rarely fail)
remove the cover - find the door switch. Test them. With the door closed, the switches should read closed. If they read open (because they are burned because you open the door when the oven is operating) the oven doesn't know the door is closed so it will not turn the mangatron on - no magnatron - no heat.
I hope this informaation helps you ...
If you require additinal help, post to this comment.
If you are pleased, please leave positive comments
thanks for using fixya.com
a
Sharpe Microwave R-316F Display Light
first remove the outer cover by removing the screws at the back.then u should see a screw behind the control board that holds it.remove that screw and the control board comes out.disconnect the wires from control board and remove remove the panel assly.then remove the screws that hold the control board to the panel.
