20 Most Recent
Internet KM-2501P Enhanced PS/2 Multimedia Keyboard Questions & Answers
How fast should my computer be?
Relative to what? In what area? What is the make and model?
What ISP do you use? All these things have an impact on it.
8/5/2015 12:49:15 AM •
Internet...
Answered
on Aug 05, 2015
Turning keyboard on
try reconnecting the keyboard by putting the pc off , or else replace the keyboard
3/15/2014 3:24:35 PM •
Internet...
Answered
on Mar 15, 2014
Wireless-keyboard-Logitech-s510
Its not the problem with the keyboard or the mouse
it seems that you need the full system scan..
of if you have wired keyboard and mouse connect them to the computer and check using them with the same browsers ... which will determine where the problem is ?
if the wireless keyboard and mouse are working fine
then need to update the drivers
or there is some problem Hack / Virus scan (not sure) but don't worry it could be a magnetic effect of speakers or monitor
you have to check them out
1/3/2010 12:08:16 PM •
Internet...
Answered
on Jan 03, 2010
Cdma mg880 cd not working need drivers
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
1/30/2009 1:42:29 AM •
Internet...
Answered
on Jan 30, 2009
Reliance cdma mg 880 is
Goodday i believe that you can try using google to search for the driver be sure to remember that you must specify what make it is and what about it you are looking for.example:KM-2501P Disc Drivers
1/4/2009 12:01:14 PM •
Internet...
Answered
on Jan 04, 2009
Internet connection
Are u using a DSL connection? If so, this intermittent disconnection is caused when the DSL filter is not working or you have not connected the modem to the DSL filter at all. Make sure the filter is connected to the main line (main telephone line) and plug in the modem to the DSL port and the telephone to the other port as mentioned on the filter.
10/25/2008 10:31:42 PM •
Internet...
Answered
on Oct 25, 2008
Internet connection
If you have dial-up internet, it will happen.
If you have DSL, make sure you have DSL filters installed for each phone.
10/21/2008 10:30:06 AM •
Internet...
Answered
on Oct 21, 2008
No internet connection
compaq what??
how old??
what do you have as wirless car or Network card??
go to the mfger web site download the new driver fo the cards and try again.
10/10/2008 3:54:58 PM •
Internet...
Answered
on Oct 10, 2008
Connection problem
how far is the wireless modem to your pc????
could be the distance or the walls in between the modem and the pc.
try to use the pc closer to the modem, if it works, then move back a little, till you cna't connect again. that is the max distance.
do you ahve sercurity set up onthe modem??
if so, you need to connect with exact encyption pass code.
10/10/2008 3:53:24 PM •
Internet...
Answered
on Oct 10, 2008
Computer hang
Windows viata responds is very slow in all account. you should shunt off the cp before you shunt off the modem.
whay do you need to shunt off the modem???? there no need to to do that. once your cp is off. every thing else is off.
10/10/2008 3:49:02 PM •
Internet...
Answered
on Oct 10, 2008
Internet explorer
This means that you have activated full screen mode in the Internet Explorer. You can activate/deactivate by pressing the F11 key on the keyboard. Plz let me know in case this doesn't work.
all the best.
10/9/2008 11:33:52 PM •
Internet...
Answered
on Oct 09, 2008
Speed of computer
Try testing the speed, go to this website and see what results you get. It takes a couple of minute so so be a bit patient.
http://www.bandwidthplace.com/speedtest/
If it's slow, report it to your DSL supplier.
9/14/2008 4:22:23 PM •
Internet...
Answered
on Sep 14, 2008
Start evrything
You have to take internet connection on your land line or mobile and put your lap in the range of adsl and conigure your lap for net.
Hop this solution works.
7/28/2008 11:59:14 AM •
Internet...
Answered
on Jul 28, 2008
Dead slow Internet connection
depends on how much packets your comp can handle with your cpu speed
heres a suggestion
hit ctrl-alt-del at same time it will bring up task manager
goto performance hit update speed to high then you want to show kernel times make sure that task manager is above the other programs now run your internet site this will tell you how much physical and kernel memmory is being used these dictate your packet datas also with comps memmory usage
6/13/2008 7:19:04 AM •
Internet...
Answered
on Jun 13, 2008
My explorer get slow down
you were hit by some spyware
or you just need to unplug modem or router for at least a minute and let packs die out
now also you could have been hacked this could also slow a comp down doing the above proceedure will eliminate the hacker with the programs below while not connected to network after these programs updates unplug once again and then run software
use this free bee programs to clear system this should help speed up your comp its a spy ware destroyer
http://www.download.com/Spybot-Search-Destroy/3000-8022_4-10122137.html
this is one program update as soon as installed
http://www.javacoolsoftware.com/spywareblaster.html
and this is the other link do update as soon as installed
these programs are very good at what they do better than virus protection in my opinion
6/13/2008 5:29:05 AM •
Internet...
Answered
on Jun 13, 2008
