20 Most Recent
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Questions & Answers
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
How do you remove old plumbing parts
Get a couple of pipe wrenches for parts that you can unscrew, a torch for copper pipes because you can unsweat the solder and pull the pipes apart. You can take these to the recycling center and get a little money back for all your hard labor. Or take a receipt ocarina saw with a few metal blades and cut them into pieces. If you use a torch don't burn down the house, if you use a reciprocating saw don't cut any electric lines. Also if the pipes are insulated there are special precautions you need to remove it
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
