20 Most Recent
Emerson Insinkerator 2.5 Gallon Water Heater - W152 Questions & Answers
The heating unit is tripping the main breaker.What
Check the current if it is over rating replace it. I am assuming you are talking about a branch circuit. If not run do not walk to the nearest electrician, you have serious problems.
Good luck,
Gil
3/1/2010 7:50:26 AM •
Emerson...
Answered
on Mar 01, 2010
Leak in the bottom of insinkerator 1-81 near reset
depending on the age it sounds like you may have to replace the unit,, insinkerator is the best on the market so when they leak it;s time for a new one ,, if not to old and under there warranty they will send some one to ifx it just call the 1-800 number on the unit
6/21/2009 2:13:36 AM •
Emerson...
Answered
on Jun 21, 2009
Can a insinkerator hot1 be hooked into a low
there shouldn't be a proble it actually would work less if you are getting low pressure,, but how did you come to the conclusion that it is low pressure,, do yo have a guage, you should not loose that much pressure on any fixture
6/6/2009 4:39:03 AM •
Emerson...
Answered
on Jun 06, 2009
THE INSTA HEATER KEEPS TRIPPING THE BREAKER?
Is this a new install or is this something that has just come up? If it is a new install, the amperage on the breaker is too low. You will have to call an electrician to come in and check to see if the romex wire is large enough to handle a higher amp breaker. If not, it could be that the breaker has become weak and tripps prematurely. If it's not the breaker its self then the heating element is bad on the unit.
3/19/2009 4:57:58 AM •
Emerson...
Answered
on Mar 19, 2009
HOW TO REPAIR A LEAKY INSINKERATOR HOT WATER
What if you back the temp down to say 165 or so would that not keep the plastic from frying?
Also does that model not sit ambient until hot water is needed and is not "hot" 24/7/365 as you
stated? Just wondering.
I have a industrial hot
then you must have a bad earth form the element . if you put voltage in a element that should be in water you blow it in seconds . if you want to get humidity leave it to air dry .
Where can I get this 25vs part today?
not his late in the day on the weekend. Not ER for water heater. wish I could have helped you more.
BUt be safe and
Tom.
Please rate us and let us know how good of a job we are doing for YOU :)
